    Once upon a time... A Puzzle
    95 Posts 15 Posters 8.8k Views 15 Watching
    • jeff hammondJ
      jeff hammond
      Outside a room there are three light switches. Each switch is connected to a different light bulb inside the room.
      Each of the three switches can be either 'ON' or 'OFF'.
      You are allowed to set each switch the way you want it and then enter the room. you can only do this once.
      Your task is to then determine which switch controls which bulb. How can you do it?
      dotdotdot
      • E
        Ecuadorian
        1. I ask someone to stay outside the room and help me.
        2. I tie a string to one of the switches, then enter the room.
        3. I call the architect and tell him how bad his design is for having put the switches outside.
        4. I give up.
        -Miguel Lescano
        • jeff hammondJ
          jeff hammond
          4. I give up.
          haha #3 sounds good.
          1 & 2 are not allowed. (or anything like those)
          4 - nah - there's a real solution
          oh, and i should add.. if you fail, something terrible will happen.. let's say nuclear war 😄
          dotdotdot
          • R
            remus
            Is there a sneaky trick to it, or is there a combination of on/offs that you can set to work it out?
            • E
              Ecuadorian
              Ok, I cheated and found the answer online. I can give a hint: The thing you can only do once is enter the room.
              And I'll give you a puzzle I've just made up. This one is for the Japanese speakers and Japanese language learners in the forum:
              3txq
              What is the next character in the sequence?
              -Miguel Lescano
              • jeff hammondJ
                jeff hammond
                no Remus. Nothing sneaky.
                [edit] well, maybe.. there isn't a sole combination of on/off's that will tell you the answer.. there's something else to it but that something else is logic based.. not something you're going to be mad about when you realize the solution..
                and yeah, you can only enter the room once.. you can do whatever you want prior to going in.
                dotdotdot
                • DanielD
                  Daniel
                  Flip the switch, then look in the room through the doorway (without entering it).
                  My avatar is an anachronism.
                  • jeff hammondJ
                    jeff hammond
                    nope - the room is light sealed.. no windows etc..
                    a hint - light bulbs are an important part of the solution.. if the switches were connected to electric fans for instance, you probably couldn't solve it..
                    dotdotdot
                    • E
                      Ecuadorian
                      Yes I could, at least with most ceiling fans 😉
                      -Miguel Lescano
                      • E
                        Ecuadorian
                        Tomorrow does sheep will be at the same hour and at the same place on the way than today?
                        You never return to the same time and the same point in space 🤓
                        -Miguel Lescano
                        • jeff hammondJ
                          jeff hammond
                          oh yeah.. i guess you could figure it out with fans..
                          i was going to use electric clocks as an example you couldn't do it with but that too would actually work.. an electric Digital clock (meaning - the display turns off instantaneously when the power is shut off) on the other hand - i don't think that would be possible.
                          dotdotdot
                          • jeff hammondJ
                            jeff hammond
                            ok, so i thought of a way you could do it with a digital clock as well..(and probably is the easiest of all)
                            i'll just go ahead and give the answer.. for ease of explanation, let's label the switches 1, 2, & 3:
                            • set switch 1 & 2 to the 'ON' position
                            • wait a minute or two
                            • turn off switch 2 and enter the room
                            • the light that is on is controlled by switch 1... the light that is off and warm is switch 2... the light that is off and cold is switch 3
                            and i'm stumped on frenchy's last question
                            dotdotdot
                              Read more the question 😉
                              • T
                                Teezer
                                Once upon a time, I got into a session with a couple of programmers who were trying to find a non obvious way to hide information in a binary format. This is one of the things we came up with.
                                The following sequence is valid under this scheme:
                                1 = 1
                                2 = 110
                                3 = 111
                                4 = 100
                                5 = 101
                                6 = 11010
                                7 = 11011
                                8 = 11000
                                9 = 11001
                                10 = 11110
                                Can you see why?
                                Real life is just another website, albeit a rather boring one.
                                • J
                                  Jim
                                  There's window in the wall and you can see the lights inside?
                                  • david_hD
                                    david_h
                                    Model it in Podium. 💚
                                    • E
                                      Ecuadorian
                                      1 = 1
                                      2 = 110
                                      3 = 111
                                      4 = 100
                                      5 = 101
                                      6 = 11010
                                      7 = 11011
                                      8 = 11000
                                      9 = 11001
                                      10 = 11110
                                      Can you see why?
                                      Ok, wait, I've solved the first 5 digits. It seems that you have to subtract and then add the relative values of the digits. I'm not a coder, so I might be way off... 😳
                                      2 = 4 - 2 + 0
                                      3 = 4 - 2 + 1
                                      4 = 4 - 0 + 0
                                      5 = 4 - 0 + 1
                                      -Miguel Lescano
                                      • E
                                        Ecuadorian
                                        That's why I came up with my own puzzle, Pilou. Anyone wants to give it a try?
                                        3txq
                                        -Miguel Lescano
                                          In Cheating 💚
                                          In fact now with Internet it's very difficult to find new problem 😒
                                          Solution is always somewhere 😉
                                          Subject: Negative bases
                                          Yes, there are negative bases. They aren't used much, but they are
                                          quite interesting. They allow you to represent both positive and
                                          negative numbers with only positive digits. For example, if the base
                                          is -2, then you have the following equalities:
                                          Base 10... Base -2
                                          -11..... 110101
                                          -10..... 1010
                                          -9..... 1011
                                          -8..... 1000
                                          -7..... 1001
                                          -6..... 1110
                                          -5..... 1111
                                          -4 ..... 1100
                                          -3 ..... 1101
                                          -2 ..... 10
                                          -1..... 11
                                          0..... 0
                                          1 ..... 1
                                          2 ..... 110
                                          3 .... 111
                                          4 ... 100
                                          5 ... 101
                                          6 ... 11010
                                          7 ... 11011
                                          8 ... 11000
                                          9 ... 11001
                                          10 ... 11110
                                          • T
                                            Teezer
                                            3txq
                                            I know nothing about Japanese, but congratulations to you and Pilou for seeing that the sequence was base minus two. Most folks have never heard of negative base numbers. 😄
                                            • 4 / 5
