    What is the Best Free Sketch-Up 7 Rendering Plugin
    extensions
    12 Posts 8 Posters 3.0k Views 8 Watching
    • A
      artisan
      I am using Sketch-Up 7 and I would like to konw what is the best free rendering plugin or stand alone program for Sketch-Up 7 (free edition).
      If I don't find a free one than I might be fored to outsource the work.
        The more easy directly interfaced are
        Kerkythea (Stand alone also) (free)
        or the very more easy Podium with restriction 500*500 in free (plugin)
        • BurkhardB
          Burkhard
          ...or the unbiased Indigo Render
          http://www.ia-plus.de
          • R
            remus
            If youve got a lot of time and need short learning curve indigo is the way to go.
            If you need your render done quickly kerkythea is probably a better option. Theres loads of tutorials available to get you started, as well.
            • A
              artisan
              Thanks a lot for the suggestions. And these can work with Sketch-Up (not just the Pro version) right?
              • R
                remus
                Yes, they all work with both the pro and free versions of sketchup.
                • X
                  xrok1
                  indigo is alot easier to use and you get better results with much less effort IMO. 9 times out of 10 you can get a great render with the click of a button. be propared to wait overnight for the results though.
                  β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                  • R
                    rcossoli
                    Free
                    kerkythea
                    indigo...
                    standalone
                    fry render
                    kerkythea
                    maxwell...
                    free and standalone??
                    kerkythea the best choice πŸ‘
                    πŸ˜‰ πŸ˜‰
                    THREEDIMENSIONSWEB dot COM
                    • A
                      artisan
                      Thanks everyone for the tips. And thanks for the heads up about the rendering time. I thought that only applied to renders for 3D's MAX and Maya.
                      • honoluludesktopH
                        honoluludesktop
                        IDX renditioner, Podium, Kerkythea, and the Su2Pov3 plugin (if your OS is Windows based) for Pov-Ray. All have their good, and bad points. It also depends on what you are primarily interested in rendering.
                        • FrederikF
                          Frederik
                          Kerkythea and Podium are available for Mac... πŸ˜‰
                          Cheers
                          Kim Frederik
                          • honoluludesktopH
                            honoluludesktop
                            Sorry for the misunderstanding, but I was only referring to the Su2Pov3 system.
