    Export 3D picture only
    3 Posts 2 Posters 463 Views 2 Watching
    • P
      pollux314
      Hi everybody !
      Beginner on SKETCHUP, I'd like to do a 2D export from my picture without the backround (wich represent a virtual horizon, a virtual floor and a virtual sky). I just want my object.
      Is it possible ?
      Thanks.
      • N
        nikola87
        window > Styles > and than select one where the sky and ground are white (default styles > "03 shade" does the job), when you send it to Lay Out, it can be saved as PDF with transparent background... or simply export the image from SketchUp in JPG, and use Photoshop to cut the backround sky and ground.
        • P
          pollux314
          Ok, thank you so much ! 😍
