    Sketchup controll panel
    11 Posts 6 Posters 2.1k Views 6 Watching
    • M
      MRN Studios
      Ok I need help with something u know when click up aboth on the toolbar by the sketchy physics buttons and stuff its the UI button when u click on that its supposed to bring up the sketchup control panel with the little slider bars right but when I click on it for some reason instead it brings up the sketchup inspector so I was wondering if anyone could tell me why its doing this or if there is anyway to change so if some one could help thanks.
      mrn
      • N
        nosam55
        hit the play button and it will work.
        • M
          MRN Studios
          no um the when I hit that it plays the sim but doesnt do anything else.
          • P
            Physicsguy1
            you need to have a controllable joint that is controlled by a slider located on the control panel, and an object must be connected to the joint. then you should have a slider
            • M
              MRN Studios
              ya i do ive tried like a moter a piston a servo all of the controlled joints but it still comes up with the inspector for some reason.
              • W
                Wacov
                When you press UI, the inspector is SUPPOSED to come up; that's what the UI is, it's for setup of the simulation; the control panel with the sliders comes up when you start the simulation, by pressing play.
                EDIT/ You do have the latest version, don't you? The first version didn't have a control panel. /EDIT
                • C
                  cdauscher
                  maybe here is a solution !
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=9586
                  Stoff
                  • M
                    MRN Studios
                    Ok thanks for the link um I edited the controlpanel.rb and now when I click play um it does bring up the the controlpanel now but its just a blue window any sugestions?
                    • C
                      CPhillips
                      I think this is a bug I fixed today. Under some conditions sliders wont appear in the control panel. Fixed in next release.
                      • M
                        MRN Studios
                        Ok so there is no way of me making it work with this version and also when is SP3 coming out.
                        • C
                          CPhillips
                          Put a slider with the same name in some other place (like magnet strength) and it should work.
                          SP3 has no specific release date. Just "when its done"
