    Sketchup controll panel
    11 Posts 6 Posters 1.9k Views 6 Watching
      MRN Studios
      Ok I need help with something u know when click up aboth on the toolbar by the sketchy physics buttons and stuff its the UI button when u click on that its supposed to bring up the sketchup control panel with the little slider bars right but when I click on it for some reason instead it brings up the sketchup inspector so I was wondering if anyone could tell me why its doing this or if there is anyway to change so if some one could help thanks.
      mrn
      • N Offline
        nosam55
        hit the play button and it will work.
          MRN Studios
          no um the when I hit that it plays the sim but doesnt do anything else.
            Physicsguy1
            you need to have a controllable joint that is controlled by a slider located on the control panel, and an object must be connected to the joint. then you should have a slider
              MRN Studios
              ya i do ive tried like a moter a piston a servo all of the controlled joints but it still comes up with the inspector for some reason.
              • W Offline
                Wacov
                When you press UI, the inspector is SUPPOSED to come up; that's what the UI is, it's for setup of the simulation; the control panel with the sliders comes up when you start the simulation, by pressing play.
                EDIT/ You do have the latest version, don't you? The first version didn't have a control panel. /EDIT
                  cdauscher
                  maybe here is a solution !
                  http://www.sketchucation.com/forums/scf/viewtopic.php?f=61&t=9586
                  Stoff
                    MRN Studios
                    Ok thanks for the link um I edited the controlpanel.rb and now when I click play um it does bring up the the controlpanel now but its just a blue window any sugestions?
                      CPhillips
                      I think this is a bug I fixed today. Under some conditions sliders wont appear in the control panel. Fixed in next release.
                        MRN Studios
                        Ok so there is no way of me making it work with this version and also when is SP3 coming out.
                          CPhillips
                          Put a slider with the same name in some other place (like magnet strength) and it should work.
                          SP3 has no specific release date. Just "when its done"
