    Message "there was a problem exporting to this file"
    Scheduled Pinned Locked Moved LayOut Bug Reporting
    layout
    23 Posts 12 Posters 35.5k Views 12 Watching
      @stevejlv said:
      I had the same problem. In my case I resolved the issue after setting "Preserve Scale on Resize" on every Sketchup Model View.(put the check mark on)
      No more problems after that.
      Steve, is this in LO3? Your profile indicates you are still using SketchUp 8 which implies LayOut 3.
      • J
        Jef.Coelho
        I was having this problem every time added some image format, I had problems with todos.Na attempt to find a solution, I found that if I put the image in another file open and CTRL + C, I can paste in my original document and export PDF in any capacity. With me this problem only occurs when the document has pictures, only with inserted sketchup, all is well.
        • S
          studio constantine
          I hope you might have figured out the problem since it's been a long time I'm answering, I don't what the issue is, but there is a solution available, you can go to "Print tab - print as a file - choose the path - Print" you'll get the PDF file.
          Thank You.
          • 2 / 2
