    Iterating over the faces of a component - without exploding
    30 Posts 6 Posters 2.4k Views 6 Watching
      talig
      I've been trying to iterate over the faces of a component without
      exploding it, in the following manner:
      Let c be that component.
      Then d = c.definitions.entities
      for each entity in d - put in in an entities_array.
      iterate over the entities_array: If an entity is a group, take it's
      entities and add them to an entities_array
      if it's a face, add to a result array.
      I'm comparing the results of this to that of "Explode".
      I get the same number of faces, but the calculations I'm using them
      for later disagree.
      I was thinking it might be related to the face's Normal Vector, but
      that seems improbable to me that using the aforementioned method and
      "Explode" will differ in such a manner.
      Essentially, the calculation performed is "raytracing" - I'm checking
      if a point in a face is visible from another point in the model.
      Has anyone seen something like this? Tell me where's the error?
      • Tali
      Avatar: all rights reserved to Bryan Eppihimer
        hm... not sure. can you post the iterating code snippet?
          talig
          Certainly. The point is to get an array of faces in the end of it all. I don't need the edges, and I don't count them even when I explode the component in advance.
          def get_faces(object)
          	entities = []
          	type = object.typename
          	if type == "Face"
          		return [object]
          	elsif type == "Loop"
          		return [object.face]
          	elsif type == "Group"
          		entities = to_array(object.entities)
          	elsif type == "ComponentInstance"
          		entities = to_array(object.definition.entities)
          	result = []
          	i = 0
          	while i<entities.length do
          		entity = entities[i]
          		type = entity.typename
          		if type == "Face"
          			result << entity
          			result << entity.face
          			entities.concat(to_array(entity.entities))
          			entities.concat(to_array(entity.definition.entities))
          		i+=1
          	return result
          def to_array(entities)
          	result = []
          	entities.each { |entity| result << entity }
          	return result
          def get_all_selected_faces(selection)
          	result = []
          	for selected in selection do
          		entities = get_faces(selected)
          		result.concat(entities)
          	return result
            Jim
            Did you know about the raytest method? It sounds like it could help you do a ray trace for visibility.
              talig
              Jim - Thanks.
              I'm using raytest. But I need a fine-grain detail.
              See, if I have a component - raytest will return the component as an answer for the ray hitting any of it's faces. I need to know which face in that component was intersected. More accurately, I need to know that a certain face that should have been intersected, isn't - because it's shaded.
              Thomthom - any thoughts?
              Thanks again guys,
              • Tali
              • Chris FullmerC Offline
                It also returns the 3dPoint that it hits. You could run that point against all planes of all the faces faces in the component with the .on_plane? method. If it truly hits something, there should be one plane in that compnent that would return true in that comparison.....right?
                Chris
                All my Plugins I've written
                  talig
                  Chris -
                  Thanks again. You are correct, but again - that is not my use case.
                  I repeat the question:
                  This code SHOULD work, it's unclear why whatever calculation I'm running on it, disagrees with the result on the exploded component.
                  Essentially - they both provide an array of faces, and it should be the same faces in both cases, but it seems like it isn't.
                  Why?
                  • fredo6F Offline
                    fredo6
                    Talig
                    A few remarks on your script.
                    You must accumulate the transformations to get the real geometric coordinates of the elements you traverse. If your raytest hits a component 'cp3', embedded in 'cp2' and 'cp1', then you should use
                    t = cp1.transformation * cp2.transformation * cp3.transformation
                    Then, you do as Chris suggests, cycle through the faces of component3, and perform 2 tests with the point 'ptray' returned by model.raytest:
                    1. Check if on plane (fast test)
                    2. check within the face (more greedy, especially when face has holes)
                    lfaces = []
                    cp3.definition.entities.each do |e|
                        if e.class == Sketchup;;Face
                           plane = [t * e.center, t * e.normal]
                           lfaces.push e if ptray.on_plane?(plane)
                    myface = nil
                    tinv = t.inverse
                    ptlocal = tinv * ptray
                    lfaces.each do |face|
                       status = face.classify_point ptlocal
                       if status > 0 && status < 8
                          myface = face
                          break
                    #myface should contain your face
                    #Note that if cp3 is a group, you should use cp3.entities instead of cp3.definition.entities.
                    The list [cp3, cp2, cp1] is returned by the raytestmethod.
                    As a side remark, you can get an array of entities by using the standard Ruby method: entities.to_areturns a list of entities (this also works on a selection).
                    Fredo
                      How large of a component does it take for this to break? I just tried it on a simple group of 5 faces and it returned an array 5 of faces. Are you experiencing problems only on large, multiple nested components?
                      Chris
                      • fredo6F Offline
                        fredo6
                        I did not test the code (just wrote it on the fly).
                        The question is whether Raytest returns the point hit in absolute model coordinates, or in local coordinates of the component or group hit. The doc is unclear. In either case, I wanted just to tell Talig that he should use Transformations to cycle through the model.
                        Fredo
                          talig
                          Chris - that's what I said: I get the correctnumber of faces. But I make some calculation about them, and I get a different result when I use explode - though I should get the same one. Even a plain box is not working properly.
                          Fredo - I'm a female πŸ˜„
                          About the coordinates: What you're saying is interesting. I assumed I get the absolute model coordinates in any case. That's obviously true in the exploded case, but possibly the cause of the problem in what I'm trying to do. I'll check it out. Thanks! πŸ‘ (and thanks for the to_a tip!)
                          I already have everything else up and running, so thanks for trying to help - but really, no call for that.
                          All I need is an array of faces equivalent to that of an exploded component. Nothing more, nothing less. πŸ˜„
                            Heehe, yeah, I noticed that after I was re-reading some of Fredo's posts. I went back and re-read your post and realized that you already were getting the number of faces correct. My mistake.
                            I see what your saying now. Makes sense.
                            So what is the calculations you're trying to run on the faces? Or maybe you've already got it working with Fredo's great explanation?
                            Chris
                              Have you checked that the list of faces you get is the same as if you exploded them? Not just the number.
                                talig
                                thomthom - I don't know how I can check that they are the same.
                                I mean, I can work something out and save the array before explosion, then explode it and compare, but will the object comparison be good enough? Do I need to compare certain fields? I'll obviously need to sort them both to have them in the same order - which may also be non-trivial...
                                Ideas?
                                  The .to_s method of entities returns something like: #<Sketchup::Face:0xae3ce28>
                                  You could sort the results of each method, exploded and un-exploded, and write it out to two files. When you have your array just use the .sort method. Then you can compare them for differences. For short lists you can do it yourself. For larger lists if you need to test more complex models you can try with some software that compares two files.
                                    I don't think you can .sort a selection set. It always comes back with undefined method '<=>' so I'm guessing they have not built in a way to compare the values of faces to know how to sort them. Even if they implemented sort to work with just the ObjectID string would suffice.
                                    Chris
                                      Oh, that works to do that: selection.to_a.to_s.sort
                                      That will sort it by turning all face ID's into a simple string. Then it can sort them. That will come in handy,
                                      Chris
                                        I was thinking more like selection.to_a.sort
                                        Is there a .sort method for a string?
                                          talig
                                          Thanks thomthom, but who promises that that string is a good identifier, when you run different instances of the program, possibly different files (same model saved under different names), if you have the same component twice in the model? Is it documented anywhere what that hex sequence is? (I'm guessing hash, but even so it matters what it takes into account)
                                            You're right. Didn't think of that. The Hash, and .entityID changes, also if you explode the groups.
                                            But, another method: You could make a list of the areas of all faces and compare them. Mind you, if any of your groups/components are scaled you have to take that into account.
                                            • 1 / 2
