π Easy Offset | Offset selected faces in SketchUp in positive and negative offsets. Download
How does this window work? ;)
If you scale your wll to be shorter, your windows get proportionately shorter. You can program the DC window to not do that. You can make it always stay that same size.
Chris
Ah, you mean scaling it "sideways" in this case? I was only doing it in the direction of the wall thickness in this case (as the original examples were about it as well).
