    [Plugin] Perpendicular Face Tools (UPDATED 26-03-09)
    201 Posts 64 Posters 195.4k Views 65 Watching
      Ben Ritter
      Hi Chris,
      I installed v1.2 and the script doesn't show up anywhere, not under the Plugins pull-down, or your separate sub-list under Plugins.
      I'd appreciate your help.
      Thank you. Ben
      • Chris FullmerC Offline
        Hi Ben, sounds like it is not getting put in the correct place somehow. There should be a single file called clf_perpendicular_face_tools_loader.rb in the main plugins folder. And a folder called clf_perpendicular_face_tools that has all the other files it in (clf_perpendicular_face_tools.rb, circle_xx.png(2), square_xx.png(2), and star_xx.png(2)). So make sure everything is in the right spot and let me know if that helps. If not, we'll keep trying,
        Chris
        All my Plugins I've written
          Ben Ritter
          Chris,
          My folders are configured just as you say and no-go. I even deleted all the files and reinstalled the zip file.
          I'm puzzled too, because on another computer it works just fine. ❓
          I appreciate your help and love your script (on the other computer 😉 )
            OK, one last thing to try before we dive into deep troublshoot mode.
            This is one of the few scripts that I wrote where I toyed around with the idea of disabling it by default. So just go try to enable it in the preferences menu - Window > Prefences > Extensions and make sure it is turned on. If that does not do it, then I'll PM you a new tweaked script that will output errors for me to look at.
            Chris
              Ben Ritter
              Chris, well there it is.
              Thank you. I forgot to check the preferences all the while thinking there we one place like that to check. I'll have to remember that for future problems.
              Ben
                taurus195
                Amazing plug-in! I've been looking for something like this for quite some time. It really is a time saver, thank you.
                  snowflake
                  Hi Chris, I've had some trouble with your tool.
                  Using a millimeter template i was not able to get under 25,4mm radius for the circle tool
                  for your information, here is the code from the console.
                  Error: #<TypeError: reference to deleted Entity> (eval):895:inget_attribute'
                  (eval):895:in onActivePathChanged' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396 Error: #<ArgumentError: Not enough edges - at least 3 required> C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396:in add_face'
                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396:in make_face' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:306:in onUserText'
                  (eval):895
                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396:in add_face' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396:in make_face'
                  C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:306:in onUserText' C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/clf_perpendicular_face_tools/clf_perpendicular_face_tools.rb:396
                  Not sure what it means, but when i draw a circle (even bellow 25mm) on the ground plane and then use the star tool there is no problem. It works.
                    hmm, interesting. I'll set up to a mm template and try it to se if I get the same error.
                    • charly2008C Offline
                      charly2008
                      Dear Chris,
                      I used your tool extensively in the beta test of fredos Curviloft. It's a great combination. but at times appears a little error. Some objects are rotated to 180 degrees. At two or three objects, this is not a problem to turn the objects by hand.
                      Charly
                        Hi Charly, I never did quite get some of that stuff worked out. When I wrote this I knew very little about vectors/ But, I was aware of the possibility of it adding unwanted rotation to faces. So I built in the ability to rotate a face immediatly after placing it by using the up arrow key.
                        So if a face is rotated wrong, hit the up arrow key to rotate it 90 degrees. Hope that helps,
                        Chris
                          charly2008
                          Thanks Chris for your quick response. Your tip is a good help.
                          Charly
                            DIEGO-RODRIGUEZ
                            hi chris
                            long use this tool and I would like to ask you some suggestions.
                            square perperdicular:
                            if I enter a single value (for ejemmplo 20) = draws a square of 20 (as it works now)
                            but if I enter two values (eg 20,30) draws a rectangle of 20x30
                            circle perperdicular:
                            add opcion of oval
                            if I enter two values (eg 20,30) draws a oval of 20x30
                            custom face:
                            add opción for scale
                            if I enter /2 draws face , half the size of the original face
                            if I enter *2 draws face , twice the size of the face of origin
                            is it possible?
                              That would be possible to add. I"m not sure how to handle the fact that different places use . and , differntly in numbers. Is there a way to determine what the decimal delimeter is for a user's location or something?
                                DIEGO-RODRIGUEZ
                                using the (,) between numbers. is a performance equal to that of native sketchup.
                                just for that reason I put as an example (30,20 in visor vcv) for a 30cmx20cm rectangle
                                • EdsonE Offline
                                  Edson
                                  chris,
                                  there seems to be some incompatibility with SU8 as the toolbar does not appear and I cannot find PFT in your folder in the plugins menu, even though all the files are in the plugins folder.
                                  http://www.mahfuz.arq.br
                                    Edson, I have these tools on my Mac with SU8 Pro and they work fine. Have you ticked the box for Perpendicular Face tools in Preferences>Extensions?
                                    • EdsonE Offline
                                      Edson
                                      nope. I looked for it in View>Tool Palettes and it was not there. but doing what you suggested did the trick. thanks for reminding me of that. 😳
                                        It's easy to forget having to tick the boxes. More so these days because you don't have to do it for every toolbar and for those you do, it's only done once until you install the next version of SU. Glad that fixed it.
                                          Glad you got it fixed Edson - Thanks Dave!
                                          Chris
                                          • demD Offline
                                            dem
                                            Sketchup crushing very often, when use Ctrl+Z after this tools 😢
                                            • 6
                                            • 7
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 8 / 11
