    SP3 feature Emitters.
    11 Posts 6 Posters 2.5k Views 6 Watching
    • C
      CPhillips
      Bodies now have a property called Emitter. If you check this property and fill in the Rate and Strength fields the body will expel a copy of itself along the axis of the object. Its sort of like a particle system.
      Adjusting the lifetime will cause the object to be destroyed after a certain number of frames.
      Both Rate and Strength can be formulas so you can connect them to keyboard and joystick inputs and this sample shows.
      KeySample1.skp
      • C
        CPhillips
        A more interesting example. Attach a emitter body to a moving body with a joint.
        GunBot2.skp
        • X
          xrok1
          thats way too cool 😍
          the new sketchup game, shoot em up physics.
          β€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
          • H
            hobbnob
            I'm dreaming... slap slap no I'm not COOL!!!
            My WIP Thread:Here
            • W
              Wacov
              Oooooooooooohhh now that's awesome. Race ya to the first tank game! πŸ˜‰
              • B
                BTM
                ...You have over a week of a head start on me πŸ˜† I've already begun making a tank though, and will add emitters later.
                %(#808080)[(Can't wait 'til BETA's out for mac πŸ˜„ )]
                for those who want proper tank turning, input something like:
                (0.5-rightx)*1+(0.5-righty)*2
                for right wheel motors and
                (rightx-0.5)*1+(0.5-righty)*2
                for left wheel motors.
                Then you won't require any servos, and will be able to turn on the spot, like a real tank.
                mini tank mockup, without treads or projectiles, just a motor example:
                ROD2.skp
                An improvement from my last example i posted for something else, this one has the *1 and *2 for multiples of the speed; which allows the wheels on the inside of the turn to go at half speed instead of none, so the tank doesn't slow down as much when turning.
                (half speed is really full speed, and full speed is double; I think. I still don't even understand what I did myself too much...)
                • W
                  Wacov
                  ^_^
                  Thank's for that code BTM, I've modified it for my tank. It's not exactly a 'game' yet, but it's getting there πŸ˜„
                  • W
                    Wacov
                    Have a look at this. Realised that hidden/static objects will become normal when emitted, which opens up worlds of possibilities; this is a quick mock-up of a gun with muzzle flash and 'randomized' casing ejection. Just turn on hidden geometry to reveal the extremely simple workings beneath.
                    edit Sorry! Forgot to tell you; the 'A' button on the joypad fires the gun. edit
                    P.S. It's quite glitchy, as far as I can tell it's not my fault; sometimes things are emitted in the wrong direction/at the wrong speed
                    emitter_gun.skp
                    • W
                      willeykj
                      Sorry I've been late. The internal HD in my 24" iMac totally failed and replacing it is pretty major surgery. But it is cool to use suction cups to pull the glass cover away from the magnets.
                      Anyway, SP3 Beta for the Mac is in the final stages of testing. I haven't noticed any significant problems yet so I'll get it out soon and let the community help me find the problems (it is BETA after all).
                      Should have it posted sometime tomorrow.
                      Kevin
                      • H
                        hobbnob
                        hello everybody I'm just here to announce that it is possible to emit complex objects: http://sketchup.google.com/3dwarehouse/details?mid=88137d070316af4a23e2dcf3d546456&prevstart=0 this model, made by me, is a car factory, and i think everyone shoulld take a look.
                        My WIP Thread:Here
                        • C
                          CPhillips
                          Pretty cool! No idea how you did it. Yet...πŸ˜„
