    Clean Lines
    7 Posts 4 Posters 697 Views 4 Watching
      ltooker
      I am working with molding profiles. The lines look jagged on screen and in print is there a way to streighten them out so they are clean?
        remus
        I dont suppose you could post a screenshot? would help in identifying exactly what the problem is.
        my first guess would be it's an anti-aliasing thing. If you go window->preferences->openGL and change the graphics setting to one with a higher anti-aliasing you might have some luck.
          ltooker
          See file attached.
          Molding Profile
            remus
            Is this any better?
            I just smoothed the connections instead of hiding them (eraser+ctrl).
            M653.skp
              ltooker
              Still jagged. I would like to try anti-aliasing... When I go to window there is no option to go to preferences or openGL. Is there another way to modify the graphics settings?
                On the Mac, Preferences is under the Sketchup menu. Antialiasing (and generally HW acceleration) also depends on your video card. If you have a decent card and a control panel for it, there, antialiasing should be set to "application controlled".
                • W Offline
                  watkins
                  Go to Window>Styles>Edit>Edge and deselect Profiles. This should help a little.
                  Regards,
                  Bob
