    Background Image
    2 Posts 2 Posters 501 Views 2 Watching
    • C
      cjlopez4
      How do I provide a custom background or sky in SU6?
      • GaieusG
        Hi CJL,
        You can load a background image as a watermark in Window > Styles > In model (the little house icon) > Edit tab > Watermark settings. There you can play around with the settings (stretch the image for instance) etc. Make sure to have some colour for the ground otherwise the background watermark will see through your ground.
        Edit:
        Here is an example I have just made with the fist image (rather kitschy) I found on the net. Obviously there's a kind of "visual contradiction" (to say the least) between the "photo-realistic" sky and the sketchy ground plane and model itself.
