    Triangluar Line removal?
    9 Posts 5 Posters 762 Views 5 Watching
      tomot
      Is there a Ruby that's capable of scouring an object and remove excess lines that are on the same surface ?
      The attached pic shows what I mean.
      [my plugins](http://thingsvirtual.blogspot.ca/)
      tomot
        Yes πŸ˜‰
        D.B Tools / Clean Selection
        • honoluludesktopH Offline
          honoluludesktop
          Doesn't "Window > Soften edges > Soften coplaner" work for you?
            Soften coplaner
            Yes but lines are not killed πŸ˜‰
              tomot
              Yes πŸ˜‰
              whats the correct name?, I can't find it via searching! TIA
              tomot
                remus
                You could try cleanup or cleanup_edges: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
                  Sorry 😳
                  It's in this thread πŸ˜‰
                  When you make a research in a search engine write your words between ""
                  so all "D.B Tools" must be enter inside the box and research will be perfect πŸ˜„
                    There's also Delete Coplanar Edges from Didier's library.
                      tomot
                      Thanks everyone! Cleanup_model.rb did the trick!
                      with thanks to John H. Aughey for the script.
                      tomot
