Triangluar Line removal?
Is there a Ruby that's capable of scouring an object and remove excess lines that are on the same surface ?
The attached pic shows what I mean.
Yes
D.B Tools / Clean Selection -
Doesn't "Window > Soften edges > Soften coplaner" work for you?
Yes
D.B Tools / Clean Selectionwhats the correct name?, I can't find it via searching! TIA
You could try cleanup or cleanup_edges: http://www.crai.archi.fr/RubyLibraryDepot/Ruby/em_edi_page.htm
Sorry
It's in this thread
When you make a research in a search engine write your words between ""
so all "D.B Tools" must be enter inside the box and research will be perfect -
There's also Delete Coplanar Edges from Didier's library.
Thanks everyone! Cleanup_model.rb did the trick!
with thanks to John H. Aughey for the script.
