    New API doc - typos and questions
    370 Posts 35 Posters 295.5k Views 35 Watching
      Jim
      Any ideas about a way to mark these errors as they are fixed?
        We could ask Coen to have a strike-through BBC tag. [deleted] or something...
        Or, put a big fat FIXED in bold green. Might be easier.
          avariant
          From Image.explode:
          entitiesarray     an Array object of entities if successful
          which I interpret as the face and edges created in the explosion. However, the result from my testing always returns an empty array.
            I see that behaviour as well: http://www.sketchucation.com/forums/scf/viewtopic.php?f=11&t=17150&hilit=+explode
            • Chris FullmerC Offline
              http://code.google.com/apis/sketchup/docs/ourdoc/polygonmesh.html#add_polygon
              add polygon detail just repeats the add_point example.
              All my Plugins I've written
              • scottliningerS Offline
                scottlininger
                @thomthom said:
                Seems that InstanceObserver.onClose is dead as well. http://code.google.com/apis/sketchup/docs/ourdoc/instanceobserver.html#onClose
                But onOpen works.
                Thomas,
                I'm about to push an update with all of the recent changes above. This one puzzled me, though. The ToolsObserver examples work fine for me on the onOpen and onClose. Can you clarify what "dead as well" means? πŸ˜„
                Does this list work 'across-platforms' - my understanding was that PCs and Macs differ ?
                Tig, these action codes only work on the PC, but I still think I'll add them to the docs. There are some cool things in there that PC-only shops might need.
                Thanks, guys! New update should be live in the next day or so.
                • Scott Lininger
                  SketchUp Software Engineer
                  Have you visited the Ruby API Docs?
                  scottlininger
                  Jim, is there a way that I could be granted edit rights just to this thread? Then I could add a FIXED note inside the reports as I correct them?
                  • Scott Lininger
                    Dead as in: I never see it trigger.
                      ToolObservers? How are they related to onClose and onOpen?
                        remus
                        I'll ask gai if he can make you a mod for the ruby forum πŸ‘
                          scottlininger
                          I meant to say, InstanceObservers. πŸ˜›
                          In any case, they fire fine for me.
                          • Scott Lininger
                            Jim
                            Scott, there's no way to give edit-rights on a single topic. So you get edit rights to the whole Ruby Forum.
                            If you have a list of changes, we can take care of marking them fixed. I'd hate to see you spend time doing it if you have more important work to do.
                              Hi Scott, I have sent you a PM, too, about it. The mods have also be informed to welcome you in the team.
                              πŸ˜†
                                Hmm... When I tried to implement it in my plugin the onClose never fired. I also tried Jim's observer test script: http://sketchuptips.blogspot.com/2008/03/plugin-oberver-tests.html - and that never fired either. Could you post a working sample where onClose fires? (The onOpen always works though.)
                                  scottlininger
                                  Give this a go... Could be that we're seeing a sneaky bug...
                                  class MyInstanceObserver < Sketchup;;InstanceObserver
                                     def onOpen(instance)
                                       UI.messagebox("onOpen; " + instance.to_s)
                                     def onClose(instance)
                                       UI.messagebox("onClose; " + instance.to_s)
                                  model = Sketchup.active_model
                                  model.definitions[0].instances[0].add_observer(MyInstanceObserver.new)
                                  • Scott Lininger
                                    Nopes. Doesn't work.
                                      Jim
                                      Works for me...
                                        Scott just found out that it works if the script loads when SU loads. But if you put it a subfolder for instance, and then manually load it, it won't work.
                                        Jim's Observer tests never fire the event in SU7. However, in SU6 it works fine.
                                          Jim
                                          Just wondering if you have Dynamic Components on, and what happens if you turn them off?
                                            Well I'll be! After disabling DCs the onClose even works!
                                            btw, the DefinitionObserver works in SU6. But not SU7. Noticed that when I tested this observer in SU6.
                                            • 6
                                            • 18
                                            • 19
                                            • 4 / 19
