    New API doc - typos and questions
    370 Posts 35 Posters 355.3k Views 35 Watching
    • thomthomT
      UI.inputbox
      http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/ui.html#inputbox
      It should be noted that the default value types you pass to the input box controls the return types.
      http://forums.sketchucation.com/viewtopic.php?f=180&t=23288&p=197300#p197298
      • thomthomT
        http://code.google.com/intl/nb/apis/sketchup/docs/releases.html
        The release notes says:
        Cleaner, hash-based syntax for initializing
        But there's nowhere any example of what the hash should look like, keys etc.
        • J
          Jim
          Thom, you are right it needs to be documented.
          This is from the webtextures_loader.rb. The constants are defined a little earlier in the code, but this gives some idea about the keys:
           # Create our dialog.
              keys = {
                ;dialog_title => title,
                ;scrollable => false,
                ;preferences_key => WT_DIALOG_REGISTRY_KEY,
                ;height => WT_DIALOG_HEIGHT,
                ;width => WT_DIALOG_WIDTH,
                ;left => WT_DIALOG_X,
                ;top => WT_DIALOG_Y,
                ;resizable => true,
                ;mac_only_use_nswindow => true}
              @dialog = UI;;WebDialog.new(keys)
          • thomthomT
            Thanks Jim. Would probably be able to guess most - but...
            What's unexpected there is :mac_only_use_nswindow - Same as WebDialog.navigation_buttons_enabled?
            • Dan RathbunD
              Dan Rathbun
              Isn't 'nswindow' a base Cocoa (or Carbon) window class?
              I'm not here much anymore.
              • thomthomT
                hm... I Googled 'mac nswindow' seems that you might be onto something.
                http://developer.apple.com/mac/library/documentation/Cocoa/Reference/ApplicationKit/Classes/NSWindow_Class/Reference/Reference.html
                Does it give any visible difference when it's set to true as oppose to false?
                • Dan RathbunD
                  Dan Rathbun
                  I don't know. I don't have an Apple machine. [..wish I could install OSX of my 686 clone for devlopment. XCode looks like a neat IDE.] There are so many attributes, methods, etc. there it's hard to guess what the SU API is refering to.
                  • thomthomT
                    Edge.reversed_in?
                    http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/edge.html#reversed_in?
                    The reversed_in? method is used to determine if the EdgeUse object is traversed in the corresponding direction as its corresponding edge.
                    Apart from the EdgeUse typo - what does the method really do. I don't understand at all from the description what it does.
                    • TIGT
                      @thomthom said:
                      Edge.reversed_in?
                      I use it in my 'orient faces' method - although I agree that it all seems pretty arcane and badly explained. If an edge is reversed in a face it is going contrary to that face's logical loop direction. If you test an edge belonging to a selected face and that edge has that face face plus another one that both return as being either reversed or not-reversed then you know that this other face has the same 'orientation' as the selected face: if the other face has the opposite 'reversed-ness' to the selected face then it needs to be flipped over (reversed) so it orients the same way as the selected face...
                      • thomthomT
                        There's a logical orientation of the loops?
                        • TIGT
                          If you get a set of vertices for a face's loop it's always listed as an ordered array: it will be rotating 'counter-clockwise' to the face's normal if it's an external loop, or 'clockwise' if it's an internal loop... If an edge's start/end vertices break this 'rule' I think it's said to be 'reversed in the face' ? That is the order of the edge's vertices don't follow the loops 'handed-ness' so are flagged thus...
                          • J
                            jarl
                            Your help in finding typos/missing details are very welcome!
                            On http://code.google.com/intl/da/apis/sketchup/docs/ourdoc/point3d.html#+ it says that the argument is a Point3d, but it should say a Vector3d.
                            Jarl
                            • thomthomT
                              Geom;;Point3d.new(10,10,10) + Geom;;Point3d.new(20,20,20)
                              Error; #<ArgumentError; (eval);261;in `+'; Cannot convert argument to Sketchup;;Vector3d>
                              (eval);261
                              • TIGT
                                Jarl
                                If you add two pointstogether it returns a vector (or another point if it's taken as an array) ?
                                • thomthomT
                                  Color
                                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/color.html
                                  When creating a Color object you can specify an alpha value. Not mentioned in the examples.
                                  Color.new
                                  http://code.google.com/intl/nb/apis/sketchup/docs/ourdoc/color.html#new
                                  The way the arguments are presented now it looks like they are all equal, but it's actually wither RGB(A) values or a String. It also takes Hex, array with Integers or Floats.
                                  Oddly enough, you can do: Sketchup::Color.new(128) and get a Red-ish color. But not Sketchup::Color.new(128, 255) - where it will throw an error saying at least 3 values are required. So if you can specify 1, 3 or 4 values for the RGBA combination.
                                  • TIGT
                                    But the Color's Alpha value is always ignored anyway ?
                                    Whereas Alpha value for the material is used !
                                    • thomthomT
                                      Yea, that's what I've noticed as well. Confusing. Should be mentioned in the docs. I had hoped that the alpha channel would be used the the view.draw2d method, but alas - it does not. Wondering if it's by design or if it's a bug.
                                      • TIGT
                                        I guess it was perhaps an early implementation when perhaps Color and Material were the same thing ?
                                        Also I suppose it allows you to import a RGBA value from elsewhere directly into a Color, but then using the first 3 items in the array is no hardship ???
                                        Seems that the alpha could be removed as it's not needed/useful ?
                                        • thomthomT
                                          I'd rather see view.drawingcolor= make use of the alpha channel and let us draw transparent objects to the viewport.
                                          • thomthomT
                                            @tig said:
                                            That would be much more use... unfortunately with drawaren't we limited to the built-in color-set, and that has no transparency setting ?
                                            draw is currently bugged an only draws black fill.
                                            draw2d works, and you can specify any Color object (or hex,int,float,array that equal to a colour) but it ignores the alpha.
                                            • 8
                                            • 9
                                            • 10
                                            • 11
                                            • 12
                                            • 18
                                            • 19
                                            • 10 / 19
