    URGENT help needed - importing polylines
    7 Posts 4 Posters 996 Views 4 Watching
    • W Offline
      will2605
      hi all,
      im running OSX
      and am trying to import a drawing from vectorworks (v12) into sketchup (v6)
      basically the drawing is a map of a part of a city that i have drawn the buildings in 2d fill with the intention of push pulling up to their height in sketchup. i am exporting as a DWG file but when i import in sketchup only the buildings with 4 corners seem to come through. any building with more than 4 vertices has disappeared! the same happens whether or not the 2d fills are drawn as a polyline or polygon... im stuck!
      any help would be greatly appreciated!
        Aidus
        I can try import export on my pc if You post your files.
        Actually i have nothing to say about this yet. I need to see it by myself.
        CPU: Intel Core i7 Extreme Edition 965
        RAM: OCZ Gold DDR3 1600MHz 12Gb
        Video: Asus Radeon HD4870 X2 2Gb
        Mobo: Asus P6T Deluxe 1366 Intel X58
          linea
          Have you hatched the buildings in on the plan (you say "fill"). Remove it if you have and try again.
          • W Offline
            will2605
            its actually behaving rather strangely in that if in vectorworks i draw a box with a fill in it (solid fill so not a hatch or pattern) only the outline box appears in sketchup (ie just 4 lines - it doesnt behave like polyline or polygon)
            if i draw a box, fill it and then remove to external line (so just the fill remains) the fill becomes visiable in sketchup as i want. but doing it this way only allows for simple fills to work (no more than 4 corners)
            its really annoyiing and means that i might have to spend a day or two drawing all these buildings again in sketchup....
            thanks for the replies so far guys
              Aidus
              Sketchup does not import hatch. Only boundaries if they are drawn with lines and no matter what lines.
                BillW
                I did a quick test from VW 12.5 PC with a filled polygon, polyline and rectangle exported as DWG 2004/2005/2006 with "Top Plan" view with all "2D fills and Files" check boxes checked and VW file units set to "Feet/Inches", imported into Sketchup 6 - units inches and all came in OK.
                As you are working on a city map, I suspect the world origin may be a long way from the centroid of your graphics which may be causing a problem. Also make sure the units match between the export from VW and import to SU (which you probabaly have checked)
                • W Offline
                  will2605
                  cheers bill. very helpful.. ill check again
