    [REQ] PurgeAllHidden
    3 Posts 2 Posters 798 Views 2 Watching
    • K Offline
      kwistenbiebel
      Hi all,
      It happens to me a lot, when working on a project, that I tend to hide a lot of objects and geometry on the way.
      A lot of these hidden items are nested.
      At the end of a design session, when I am happy with what is on screen, I would like to get a clean file and purge all that is hidden out of the scene.
      Unfortunately, doing this manually, is very tedious.
      I was wondering if it is possible to have a ruby that purges all those hidden elements, even if they are nested.
      Would be wonderful.
      What dou you think?
        You want a plugin which deletes all hidden entities?
        Should be fairly easy to write. But I'm thinking there might be a gotcha creeping up. What about lines in a mesh which are hidden? If they are deleted the connected faces will disappear. I suppose ignoring edges connected to visible faces would work...
        And what about geometry on hidden layers?
        • K Offline
          kwistenbiebel
          You are right. I didn't think about hidden lines defining surfaces.
          Maybe just hiding the lines that do not define surfaces?
          Yes, hiding hidden layers could be a nice option...although doing that manually isn't that diffcult.
