Convert into .skp??
I'm wanting to use the program RSP 3D PDF which only runs using Sketchup files. The problem is that I want to load 3D models I have created from actual 3D object. These models are currently in .scn and .obj formats but I will need to convert them into .skp(sketchup) format to run them in this program.
Does anyone know of a program or converter which exists that can convert .obj files into .skp? If not what file formats are the best suited to be converted into .skp formate and where would I need to go to convert them?
Hi Arpa,
There is an obj importer although (as it says) "it works sometimes but not all the time". Give it a shot and see. (It doesn't import textures either).
Thanks for that Gaieus I'll give it a go.
I would really prefer something that will import textures as well anyone know of one that will do that? -
I have the same problem, nice guide.
Register LoginAdvertisement
