    Resuming Paused Indigo Render
    2 Posts 2 Posters 457 Views 2 Watching
    • N
      newbuilder
      I tried to resume a render I had stopped last night. The file type read " igi " and Indigo was looking for " igs ". Is this because I stopped the render rather then paused it? I could not resume rendering it. I assume it is because I stopped render and should have paused.
      • R
        remus
        The .igs file should be in your skindigo, i think it's called default.igs.
        Its worth noting that this will be deleted when you start a different render, though, so it's better to go plugins->skindigo->export scene if you plan on resuming the render.
