    Help with curves
    4 Posts 3 Posters 582 Views 3 Watching
    • C
      Clarencecat
      I'm trying to model a spanish villa which has curved inset windows, as in
      attached, can anyone tell me how to achieve this?
      thanks
      Ed
      • B
        BUDLA
        thanks
        Ed
        Use this: http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=11212&st=0&sk=t&sd=a&hilit=toolsonsurface
        and this:
        http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=6708&st=0&sk=t&sd=a&hilit=Joint+Push+Pull
        Budla
        • V
          vieucaillou
          Hello !
          You may also try with an intersect with model with a volume having the same shape and dimensions as your window. Then, cleanup what is unuseful. 😉
          http://escargot-archi.eu
          • C
            Clarencecat
            Thanks everyone for your help -
            i used intersect & joint push pull - you're all brilliant!
