    Rhino or Modo?
    extensions
    22 Posts 11 Posters 12.2k Views 11 Watching
    • zivotinjaZ Offline
      zivotinja
      To be quite honest these two apps do not tango well together. SketchUp and Modo do. I have tried them inside out. Rhino to SketchUp and vice verse no good. I mean it works from a hobby user's perspective. However, this being said I did not cover the essence of this comparison. Modo and Rhino are entirely different beasts. One uses NUrbz as underlaying algorithmic engine the other the polygon engine. Two different things. This is the biggest problem when you go back and forth. Polygons are good for many things but primary advantage is that all rendering engines use only polygon based models. basically even if you have a NUrbz model it will convert it for better or worse into polygonal model. Modo is a polygonal modeler but it is much harder to work with free flowing - developable, surfaces and CAD/CAM technologies. It's harder to produce a prototype than straight out from Rhino. Also interface and app. functions are radically different. Try them out. See what you feel comfortable with
        Ps : Moi V2.0 Moment of Inspiration has now colors, lightings options work renders, a sort of tricky system of "layers", "objects" etc...better OBJ mesher than Rhino, Export SKP πŸ˜‰ (so you can take some your favorite SKP renderers πŸ˜‰ )
        Moi = 295$ Rhino = 1260$ (same father) πŸ˜‰
        By Mario
        http://moi3d.com/gallery/images/MOI_ATL_videata.jpg
        Render Atlantis
        http://moi3d.com/gallery/images/MOI_ATL_render 02.jpg
        • 2 / 2
