    [Bug]Win32api.so and Sketchup7
    12 Posts 9 Posters 3.1k Views 9 Watching
      CPhillips
      I think there is a bug with using Win32api.so and Sketchup7. It looks like the Win32api.so links against msvcr71.dll which was included in Sketchup6 but not 7. Some users may have that .dll in there system directory and some dont. Especially on newly installed machines.
      I think the solution is to make sure the user has it installed either in the windows system directory or perhaps in the Sketchup directory.
      But a better solution might be to use RubyDL instead of win32api. It works under Sketchup and is like a zillion times better at interfacing between DLL's. It works on Mac and Windows and even seamlessly supports structs and function pointers.
      • daikuD Offline
        daiku
        Chris:
        My plugins use Win32api.so, and so far I haven't seen any problems with SU7. But I upgraded from SU6, so that may be why. Tell us more about RubyDL - this is the first I've heard of it. CB.
        Clark Bremer
        http://www.northernlightstimberframing.com
          linea
          Although I don't really understand what you are talking about, you might be on to something that has been puzzling me since I bought SU Pro 6 and installed it on Vista 32 bit when it was first released (I have since installed service pack 1). I have a fairly powerful machine but SU has always seemed a bit clunky and I always have difficulty getting ruby scripts to run, and yes, I always folow the instructions. I have never got Sketchy physics or indigo to run. SU7 is no better.
            CPhillips
            @daiku said:
            Chris:
            Its part of the standard Ruby install and I just copied the files over. It is meant to do the same job as win32api.so except it has a much nicer interface.
            Here is code to call the getKeyState function in user32.dll using win32api.so
            require 'Win32API'
            $win32GetKeyStateFunc=Win32API.new("user32.dll", "GetKeyState", ['N'], 'N')
            $win32GetKeyStateFunc.call(0)
            And the same thing with RubyDL.
            require "dl"
            require "dl/import"
            module KeyInput
                extend DL;;Importable
                dlload("user32.dll")
                extern "int getKeyState(short)"
            KeyInput.getKeyState(0)
            The first good thing is the declaration of the function is more C like than the winapi method of passing the parameter types in a array. And you can call the function without the .Call().
            RubyDL also allows structures to be passed back and forth where win32api does not.
            (www.jbrowse.com)
            Chris
            RubyDL-libs.zip
            • fredo6F Offline
              fredo6
              Chris,
              Interesting.
              But how does it work on Mac?
              Fredo
                CPhillips
                Chris,
                Interesting.
                Fredo
                I wasnt clear. You still need a Mac .dylib that exports the same functions as a Win .DLL. But I did included the dl.bundle file that the Mac version needs use a .dylib.
                  This is very interesting.
                    dburdick
                    @cphillips said:
                    @daiku said:
                    Chris:
                    require 'Win32API'
                    > require "dl"
                    > require "dl/import"
                    > module KeyInput
                    > end
                    (www.jbrowse.com)
                    Chris
                    Hi Chris,
                    I tried your DL example in SU7.1 and it didn't work for some reason. The DL files are all installed correctly in the SU plugins folder. Here's the error:
                    load 'DLTest.rb'
                    Error: #<RuntimeError: C:/Program Files (x86)/Google/Google SketchUp 7/Plugins/dl/import.rb:126:in symbol': can't find the symbol getKeyState'>
                    Any idea why it's bombing on this?
                      dburdick
                      I found the problem.
                      getKeyState should start with a caps GetKeyState
                      • H Offline
                        hvanessen
                        I had this problem when i installed RP Treemaker. Directly when i started SU 7 i get the sign that RP Treemaker wasn't loaded because of the WIN32API.
                        I searched my disc for the fle msvcr71.dll en copied this file into the plugins directory.
                        Now i have no problems, everything works perfectly. So the solution is copy the file to the plugins directory ☀
                          cjthompson
                          Do you know which version of Ruby you took the Win32api from?
                          • Dan RathbunD Offline
                            Dan Rathbun
                            Just as a head's up, so you'll know... Win32API.so is not distributed with Ruby 1.9.x and up. It is replaced by Win32API.rb, which is a translator script, that 'fools' old calls to the Win32API.so, by translating those calls into DL library calls.
                            It is supposed to work transparently, because most uses would load the so by simply:
                            require 'Win32API'
                            The require method looks for .rbfiles first, so it would load the new translator, instead of the .so, ... in a normal ruby install.
                            I'm not here much anymore.
