    Pick vertex?
    6 Posts 2 Posters 545 Views 2 Watching
      I want to be able to pick a vertex, how would I do that? The pickhelper doesn't seem to return vertices.
      Also, I got this little test code:
      def pick
      	Sketchup.active_model.select_tool Stix.new
      class Stix
      	#def self.onMouseMove(flags, x, y, view)
      	#end
      	def onLButtonUp(flags, x, y, view)
      		ph = view.pick_helper
      		ph.do_pick(x, y)
      		picked = ph.all_picked
      		puts 'picked;'
      		puts picked
      When I group a cube and click on a point that would be a vertex, all_picked return the group multiple times.
      picked;
      #<Sketchup;;Group;0x88c5ce0>
      As oppose to this when it's not grouped, or inside the group.
      picked;
      #<Sketchup;;Edge;0x8851fe8>
      #<Sketchup;;Edge;0x8851fd0>
      #<Sketchup;;Face;0x88545b0>
      #<Sketchup;;Edge;0x88545e0>
      #<Sketchup;;Face;0x8851fb8>
      #<Sketchup;;Face;0x88545c8>
      I had expected it to list the group as well as the edges and faces inside it.
      How come I get this result? What's the point in returning the same group multiple times?
      • fredo6F Offline
        fredo6
        You should use an InputPoint instead, if you are just interested by the vertex.
        ip = Sketchup;;Input.point.new
        ip.pick view, x, y
        vertex = ip.vertex   #or nil if none
        edge = ip.edge #or nil if none
        face = ip.face   #or nil if none
        #use tr * ip.position to have the absolute coords if your vertex is embedded
        # in groups or components
        tr = ip.transformation
        redo
          Ah! Thanks Fredo!
          If it's nested in multiple groups, do I have to do transformation * transformation on all groups first?
          group1.transformation * group2.transformation * ip.position ?
            Still curious to why pickhelper returns the group so many times though...
            • fredo6F Offline
              fredo6
              No, just use ip.transformationto get the coordinates in the current active_model (it is cumulative).
              You don't have to use the pickhelper, except if you want to know more about the hierarchy of groups and components.
              Fredo
                Thanks allot, once more. πŸ‘
