    [Plugin] Component Spray update
    29 Posts 16 Posters 51.7k Views 16 Watching
    • Didier BurD Offline
      Didier Bur
      Hi all,
      Here is a bug fix of my spray tool, interfering with other scripts that use Todd's progressbar.
      Just replace old rb with this one.
      Regards,
      ENGLISH version
      FRENCH version
      DB
        todd burch
        Thanks Didier!!
        Did you see my suggestion in the Greeble thread?
          Didier Bur
          Yep, great idea !
          DB
          • Chris FullmerC Offline
            Awesome Didier, thanks so much!
            Chris
            All my Plugins I've written
            • MALAISEM Offline
              MALAISE
              Thank you Didier, for the ruby's release 👍 👍
              MALAISE
                Very reactive! ☀
                Toujours sur la brèche ☀
                  Didier Bur
                  Façon de parler, ça faisait 6 mois que ça traînait 😄
                  DB
                  • F Offline
                    Fletch
                    thanks Didier- that fixed a bug where I couldn't get it to do anything on my SU vs. 6 or 7. 😉
                    worked great now.
                    Fletch
                    Twilight Render Cross-platform Plugin for SketchUp on PC or Mac
                    • X Offline
                      xrok1
                      thanks for the great ruby!
                      i was wondering, would there be a way to get an exact number of copies, say 1 per face, at the center of each face?
                      “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
                        Jackson
                        Strangest thing, Component Spray (fantastic ruby BTW Didier!) stopped working for me a few minutes ago- I clicked to set the centre point of the spray shape, but when I clicked to set the radius it wouldn't "stick", the spray shape just moved with the cursor. I quickly searched SCF and found this update, overwrote it into my Plugins folder, but saw the same behaviour. So I went and made a cup of coffee, came back and now it works!
                        One thing I have always wished for in Component Spray would be the ability to scatter comps randomly within the spray area rather than weighting them towards the middle- or am I missing something really obvious? 😕
                        Jackson
                        • plot-parisP Offline
                          plot-paris
                          Thanks a lot for the update, Didier 👍
                          good idea, Jackson. there should be either a check box to enable/disable the behaviour or a field to type in a percentage of distribution
                          • AdamBA Offline
                            AdamB
                            Cool plugin, Didier. I really believe these kind of 'smart' tools are the way forward.
                            Jackson: The "bunching" in the middle is caused by the way the random positions are calculated.
                            Just as an experiment I added some 'clash detection' to the plugin. The idea being before it adds the instance it checks there is space for it. It really reduces the overlap of Component instances (obviously) but also helps the "bunching" in the middle because it avoids adding too many near the middle.
                            [I didn't want to make big changes to Didier's baby, so it only catches most clashes - with more work it could be made to never add overlapping Components]
                            Adam
                            PS Didier, I'll send you my changes. Ignore / use / abuse or whatever as you see fit.
                              That's interesting. I thought it was some code in there that deliberately clustered the components, simulating the effect of a forest. There are times when I want that effect and there are times when I don't. Having an extra option for this would be really nice.
                                Jackson
                                So what factor affects the otherwise random positioning? It would seem to me the only factors which could cause this obviously non-random influence on random scattering must be either
                                a) proximity to the centre point
                                b) proximity from the boundary
                                Another great addition to this script would be that rather than the density parameter being input as a percentage it could be input as a "x number of components per square metre/foot/etc. As a percentage is only representative of a fraction of a whole it can't really be used to describe density in this sense as there's no way for the script to know how big each component is, and therefore how much of the total area they will actually cover. It'd be great to be able to scatter trees randomly, but at an average of say 1 instance per 10m². Just some ideas.
                                Jackson
                                  Didier Bur
                                  Cool 👍 Thanks Adam.
                                  But I have no time now to work on my freebies, or update the depot, etc; 😞
                                  DB
                                    Jackson
                                    Your generosity with this amazing script and the ruby depot is already greatly appreciated!
                                    Component Spray already has an excellent, intuitive UI and is among a small group of ruby scripts which really should be implemented as proper SU tools IMO. Great job!
                                    Jackson
                                    • AdamBA Offline
                                      AdamB
                                      Its a bit involved but since you ask...
                                      If you use a random number generator that is normally distributed and use it in an orthogonal linear space you're all set. So compo_spray along a Line works great with no bunching. But for the Spray mode, the script calculates a random radius and a random angle around the center. However, the circumference of a circle close to the center is smaller than at the outside edge of the spray so using a normally distributed random number for the radius effectively biases position generation to the center point of the spray.
                                      Adding "clash-detection" means you can set a "N per unit area" threshold so although it tries to add more near the center of the spray, they get rejected hence you don't get that bunching.
                                      Phew....Fascinating, huh? 😉
                                        Jackson
                                        Adam,
                                        Thanks for that detailed, but very clear explanation, it hadn't occurred to me that the random scattering was calculated along the circumferences of concentric circles. That actually is fascinating!
                                        Sounds like your tweak is a useful addition. 👍
                                        Jackson
                                          plot-paris
                                          fascinating indeed. now everything makes sense. 😒
                                          • Bob JamesB Offline
                                            Bob James
                                            @jackson said:
                                            It'd be great to be able to scatter trees randomly, but at an average of say 1 instance per 10m². [/quote]
                                            I'm looking for a way to randomly place people in a room: Jackson's suggestion would really do that job.
                                            Didier: Looking forward to your having enough time to re-address this Ruby.
                                            • 1 / 2
