    Entities.add_face - does order matter
    11 Posts 6 Posters 707 Views 6 Watching
      When you pass edges to the add_face method, does the order or the edges matter?
      Reason I ask is that I'm trying a script where I take two coplanar faces, collect their edges, then filter away the inner edges, and then try to create a new face which is essentially both the faces joined. It jsut seems that some times it won't create, or the face is invalidated if I Fix Errors.
      • Didier BurD Offline
        Didier Bur
        No, AFAIK
        DB
          avariant
          Hm... I'm curious, does edge order control the face winding, which side is the "back side" or the "front side"? I assumed so, but maybe SU just makes some assumptions based on the overall geometry...
          • W Offline
            Whaat
            i am pretty sure the order of points controls the front side of the face
              tomot
              The order definitely matters. And its not discussed in the Ruby docs, as far as I know. Its even more important if its followed by a pushpull. I seem to recall you want to enter your points clockwise when creating a face. If you enter your points anticlockwise then a pushpull will produce an object with the faces reversed.
              my plugins
              tomot
                todd burch
                If you visualize the face you are creating as being drawn CCW, then when the face is created, you'll be looking at the front.
                If you visualize the face and you draw CW, you'll be looking at the back when the face is created.
                Faces created on plane z=0 will always have their normal pointing towards -Z.
                Todd
                  todd burch
                  You can test this by hand too. Establish a front elevation, and with the line tool, draw a box. CCW you'll get white. CW you'll get blue.
                    So the order matters for what's side is being up or down?
                    But does it matter for the face being created? Should all edges be organised so that edges connected to each other comes after each other in the array passed?
                      todd burch
                      Well, depending on if you care what the orientation of the face normal is, yes. An alternative approach is to just draw the face, and then figure out out if it has the normal you want, and if not, .reverse! it. And, remember it's not about "up or down". It's all about direction. On a typically drawn cube, you have 6 faces, each pointing in their own direction, having opposite faces pointing in opposite directions.
                      This is a most fundamental concept - it absolutely makes a difference. Trying to draw a four sided face with two points swapped will give you an hourglass shape with overlapping, non-intersecting lines, and possibly even an invalid face.
                        Ok, I had a feeling something like that happened. Just wasn't sure if SU sorted the edges before generating.
                          todd burch
                          You are very welcome.
