    Background
    3 Posts 2 Posters 418 Views 2 Watching
      J. D. Champion
      Hello Everyone.
      I set my sketchup for feet and inches. Right now my background is gray. For my application I need the background to be white. How do I do to change it to white?
      Thanks in advance
      John D. Champion
      • daleD Offline
        dale
        Under your window pulldown menu make sure your "Styles" is checked (open). In your Styles dialogue box select the edit button. In the edit dialogue you will see the 5 cubes representing settings. If you click on the middle one it is your background, sky and ground color settings. Click on the color chip beside "background, and change your color. Remember to un-click all boxes after you are done or it will continue to change colors on you.
          J. D. Champion
          Dale,
          It worked... Thank you very much.
          That helps me a lot.
          John D. Champion
