    Maxwell bump map.
    extensions
    2 Posts 2 Posters 871 Views 2 Watching
      Aidus
      Hi there!
      I'm really confused with maxwell bump settings. Manuals in one example say's that bump settings set to 3 is really enough but that setting can be from 0 to 200. After some experiments with differenet numbers I have not see any big changes. If they say 3 is ok then 200 must be a real mountain on my model but it isn't.
      So can anybody explain me something about that weird bump stuff? πŸ˜„ πŸ‘Š
      CPU: Intel Core i7 Extreme Edition 965
      RAM: OCZ Gold DDR3 1600MHz 12Gb
      Video: Asus Radeon HD4870 X2 2Gb
      Mobo: Asus P6T Deluxe 1366 Intel X58
      • brodieB Offline
        brodie
        I can only ditto this I'm afraid. I've run into the same problem and haven't found the solution yet either. I'll keep you posted if I find out anything as I'm going to be running into this problem again shortly with a brick texture.
        -brodie
