    Galaxy Class Starship
    35 Posts 11 Posters 6.7k Views 11 Watching
    • H Offline
      halkun
      Here's a little something I've been obsessed about for the last few days. I have to "furnish" it still. After that, I have 22 more decks left to go.
        boofredlay
        Welcome. Nice first post. I look forward to the rest.
          tomislavm
          super, continue with whole model!
            MALAISE
            Long Life and Prosperity 👍 👍
            MALAISE
            • H Offline
              halkun
              Whee! The first deck is done... I had to imageshack the picture because it's HUGE and takes up both of my screens.
              http://img11.imageshack.us/img11/2426/clipboard01gp1.th.png
              I've discovered that I'm really pushing Sketchup. With one deck it's really bogging down. I'm layering the decks, but when autosave kicks in I have to wait 15 agonizing seconds to get control of the application again. (The file is 31 meg so far)
                tomislavm
                Why 31 meg?
                  Sir
                  you can reduce the time between autosaves
                    boofredlay
                    31 meg seems high for what you are showing. Maybe you have a high res image or two hidden?
                    I turn off my autosave. I have gotten in the habit of hitting save before using a ruby script anyway and only a couple times have I lost any information.
                    • G Offline
                      Or is there any CAD import with zillions of segments in the curves? (Everything seems to be curving here).
                        dolphus
                        cool keep going bugger the poly it is looking good 😄
                        • H Offline
                          halkun
                          I found out why it was 31 meg. I had a few massive components in there that were from import experiments. I purged them and it's much smaller now. I also reworked the rear end, and I'm putting in windows proper.
                          Here are a few things that I found out that are intresting...
                          The ship is 1:1, and I found out that the insides, for the most part, are quite consistent in scale. The only real issue is that the real external size of the ship verses the published sizes are incorrect. I'm nudging around the skin of the ship and the placement of windows to better reflect what's inside. Also, because the skin is angular, there are a few more vaulted overheads (ceilings) that I took for granted.
                          By the way, here's the actual size of the ship
                          Published dimensions:
                          length: 842.5 meters
                          beam : 487 meters
                          depth : 137 meters
                          Real world dimensions
                          length : 1048.41 meters (a kilometer!)
                          beam : 738 meters(!)
                          Depth : 238 meters
                          By beam I'm going by the widest part, the saucer. Also, the plans I'm using are not Mike Okuda's I'm using the original ones that were authorized by Andrew Probert, the original designer of the ship.
                            Wow!
                            Funny thing though. When I clicked for the larger picture, I automatically pressed the scroll wheel on my mouse so I could fly around.
                            As you can guess, that didn't work too well. 😆
                            • H Offline
                              halkun
                              Deck 1 is now done. I now have real windows that look in. It took a while as I had to make a poor-man's CSG boolean component to cut through multiple walls. I should put glass on them, but I'm keen on having them open for now so you can look in. I've started on the upper second deck now.
                              the first deck is actually a self-contained multi-level platform. The ship is designed so the bridge module can be "swapped out". The upper level of the first deck is the bridge proper and is set a half-level above the lower platform. The second deck is also a two-level platform. This is actually in the ship proper, but a half-deck higher then the rest of the decks
                              One of the more interesting things is that the window for the captain's ready room actually doesn't poke outside of the ship anywhere.. I had to Munge the skin of the ship a little to accommodate the window.
                              I'm not making "The Enterprise". This is a unique ship. (NCC-1683) I did this because I tend to fret over very trivial things, and if something doesn't come out just right I can fiddle with it for hours. One of the problems is that this is an imaginary ship, filled with imaginary things made up by different people. Sometimes it's consistent, but often I have to make things up to make it fit. So it's bigger and most likely not the same aspect as the "real" Enterprise. The halls are simplified and largely it's unfurnished. This is My ship. and It feels good that I don't have to adhere strictly to a floor plan or size aspect.
                              Maybe when I'm done, I'll "rent" the rooms and people can fill them and I'll add that to the ship.
                              I leave you with a picture of all the floor plan levels stacked semi-transparently. You want to see what a ghost ship looks like?
                                tomislavm
                                My hearty congratulationst!
                                It is something that I have ever seen.
                                How long did You meke it?
                                • H Offline
                                  halkun
                                  The plans are freely downloadable. They were done by Ed Whitefire under the supervision of Andrew Probert. The "Official" plans were done by Mike Okuda. I own those too, but I like Whitefire's better. Firstly because they are already scanned, but mostly because it's a whole new take on the ship. Also the rooms are "blank" which leaves more to the imagination. I'll be taking from both sets of plans when I make my ship. It will be a nice mix between the two.
                                  You can download the Whitefire plans here...
                                  (www.cloudster.com)
                                    tomislavm
                                    Thank You for the link!
                                      MALAISE
                                      Really thanks for the link halkun 👍
                                      MALAISE
                                      • H Offline
                                        halkun
                                        Here's a little update, because the ship is modular, you can easily fill space with components. The cool thing is that ship parts can be knocked out in as little as 2-5 minutes. I'm making the internal parts now and I thought I would share. I can share the components template if anyone wants to help generate these parts. They are super-simple to make. They are nice and ambiguous and require a touch of imagination.
                                        • H Offline
                                          halkun
                                          I forgot to post the ship!
                                          Here you can see the lifeboats in the X-ray view and how the poke out the ship. You can also see into the ship from the windows now. Speaking of windows, now that I look at it, I should be putting glass in them.... What do you guys think?
                                            Geez louis! That is impressive!
                                            But... I don't think the lifeboats are supposed to poke out. Are they?
                                            • 1 / 2
