    ๐Ÿ”Œ Smart Spline | Fluid way to handle splines for furniture design and complex structures. Download
    Galaxy Class Starship
    35 Posts 11 Posters 6.2k Views 11 Watching
    • H Offline
      halkun
      There is an issue where I'm running into scale problems. The actual lifeboat is 4 meters wide, and matches the plans I have, however, with the room it sits in, there is a bit of a clearance issue as they don't fit in a deck! However, the original model shows a bit of relief for the lifeboat hatches and so I'm chalking it up to "close enough".
      • H Offline
        halkun
        More comps, I'm calling it a night tonight.
          Sir
          awesome work! keep going ๐Ÿ‘
          • H Offline
            halkun
            More misc comps, I need these to start building the rooms. The furniture comps are next but I'll just probably nick those from the warehouse.
            • pbacotP Offline
              Where the hatches would project too much above the skin, the lifeboats are recessed in the deck structure below. It's an engineering solution proposed by Scotty while still in Fleet Academy, a little known fact.
              • H Offline
                halkun
                Ugh! I'm grinding now. There are a lot of comps to make.
                • X Offline
                  xrok1
                  ๐Ÿ‘ wow thats dedication, i hope you're watching the face orientation. i see alot of reversed faces. if you ever render this they'll give you troouble.
                  โ€œThere are three classes of people: those who see. Those who see when they are shown. Those who do not see.โ€
                  • H Offline
                    halkun
                    Each is a comp onto themselves. I'm endlessly tweaking them. There are the "rough drafts", but the cool thing is that when of mess with one, you mess with all of them. When they are placed and fitted, I'll get all the sides right (Messing with one causes all of them to change) A good example is the "door" comp that is just an open hole. I can add the two sides and every doorway gets the upgrade.
                    • pbacotP Offline
                      Great work! You can make the doors a dynamic component with a door that slides away and goes shhhisssss-CK, when you click on it.
                      • H Offline
                        halkun
                        I may just keep the doors open. When I'm done I want to export this so anyone can turn the model into anything they want. If you have dynamic objects they wont work if you convert it to, say, a half life map file. (You will have to delete and recreate several thousand doors. Right now for some reason you can't even walk around properly because the "walk" camera is so touchy. I wish there was an option to turn that down, or to add WASD keys to move.
                        • X Offline
                          xrok1
                          i think it will help with walk mode if everythings to scale? although it may be, i'm not sure, just trying to help.
                          • H Offline
                            halkun
                            The problem is when I got it to scale, that's when everything got touchy. When I was just on the 1st Deck, it was awesome, but I have templates for the whole ship now and it's huge. I'm thinking that's it.
                            • H Offline
                              halkun
                              Here's a little update. I picked up the project again after having some free time...
                              Here is an external shot of the decks I have done...
                              http://img413.imageshack.us/img413/1460/pic1msk.jpg
                              The second picture I have here is an x-ray view. I try my best to get the windows to line up with the rooms below. You can actually stand in the room and look out through the glass.
                              http://img413.imageshack.us/img413/3613/pic2r.jpg
                              Here is the control tower inside Hangar Bay 1. I still have to make a floor for deck 4, but you can see it's a neat looking structure we never saw in the show.
                              http://img413.imageshack.us/img413/4470/pic3y.jpg
                              These windows are going to be the death of me...
                              http://img413.imageshack.us/img413/7690/pic4a.jpg
                                liam887
                                good work, would it not be easier to construct each deck in a separate file and then assemble them when complete. make things run faster for you at least?
                                Looking good anyway, you should PM Marian he should be able to give you some tips and tricks where star trek ships in sketchup are concerned?
                                VISIT MY ONLINE GALLERY
                                  tomislavm
                                  Yesterday I have seen new Star Trek, it is great and Your model is perfect, thank You !
                                  • 2 / 2
