    Sketchup shadow rules
    6 Posts 3 Posters 970 Views 3 Watching
    • M
      mirjman
      does anyone know what the technique is called that sketchup uses to control the 3d shading look when the sun is turned off? what are the rules for this? what I am talking about is that when you look at a face straight on, it will be much lighter than looking at it from a very shallow angle. I would like to know more of the details about how this works.
      • A
        avariant
        I don't know the right answer, but I suspect it's whatever OpenGL uses as a default lighting. I think that it is "Phong" lighting. I know there are lots of equations out there for Phong. Sorry if that's no help.
        • R
          remus
          I dont know a lot about how SU renders objects, although im fairly sure it uses Gouraud shading for smoothed objects.
          • A
            avariant
            😳 My mistake. Gouraud is the default shading for OpenGL, not Phong.
            • M
              mirjman
              thanks for response guys. I assume when you check "use sun for shading" it is just using the sun position to calculate the angle to the normals rather than the camera? same technique though?
              • A
                avariant
                It looks like that's what's going on to me.
