    SP3 feature SketchyReplay.
    17 Posts 7 Posters 3.0k Views 7 Watching
      CPhillips
      SP3 includes some animation recording and playback support.
      If you press the Record button on the SketchyReplay tool bar it will toggle recording. If recording is on while the simulation is running it will at the end prompt you to save the animation data. The data is stored in the model.
      Once data has been been stored you can play, pause and rewind the animation by using the buttons on the tool bar.
      The Plugins->SketchyReplay menu has 2 options. The Export option will save a separate .SKP for each frame of the animation. The Erase option will purge the animation date from the model. Animation data can be quite large.
      [flash=648,480:2vn0p1w9]http://youtube.com/v/Q2zm5zSQ74E[/flash:2vn0p1w9]
      • V Offline
        Verrou
        Very cool! Good work 😄
          l.frisken
          this will be fantastic for rendering !!!!!
            CPhillips
            I had that in mind. It currently exports just to series of .SKP files. But it really could output to just about any format.
              l.frisken
              oh i see now what it does.... this could potentially be really usefull for indigo animation if it exported to different scene tabs
                CPhillips
                You mean make a copy of the objects at every frame and unhiding them on each page? I tried that and it works ok for short and/or simple scenes. But anything complex or long and it was too much data. SU was freezing up.
                • K Offline
                  kwistenbiebel
                  Thank you Cphillips for considering people using render software.
                  Indeed, the animation spread over scene tabs is the strategy we need to get there.
                  Too bad it only works for simple scenes, but it would be very cool to have the option.
                  For instance, for archviz, having some cars driving around in streets, doors opening etc...
                  • P Offline
                    Platypus5
                    Is there a way the animation could be automatically made into a separate file?
                      CPhillips
                      I am willing to work with the render guys to support animation export. But putting the data in the pages isn't really feasible. Sorry.
                        l.frisken
                        well I know that Indigo and Kerkythea both support animation export of some kind movie output, and because I'm biased towards Indigo I reckon whaat might like to incorperate this as one of the features of the new version of skindigo he is making...
                        • W Offline
                          Whaat
                          you reckon right! 😄
                            l.frisken
                            yippee!
                              darkPhysics
                              Maybe you should make an update where you can export in video formats as avi,divx,quicktime...
                                CPhillips
                                Sequential image output may be possible but not movies.
                                  darkPhysics
                                  When will you make it??? And is it possible to save every frame as a scene (in any future version???).
                                  • K Offline
                                    kwistenbiebel
                                    Yes, each frame as a scene would be super, cause then we can use render engines on it.
                                      CPhillips
                                      The next version will support rendering options better.
