    Garden collection
    101 Posts 42 Posters 27.9k Views 42 Watching
      Why so many groups? Are they deeply nested?
      Reason I ask, is that V-Ray will take longer to parse scenes which has many deeply nested groups/components. Also, is all material applied to the geometry or the groups.
      V-Ray will also slow down, quite notably very quickly, from materials applied to groups or components. Just a FYI.
      • soloS Offline
        solo
        Every stem and every leaf is a seperate group, only one level down (Component --> 86 groups)
        Renders fast in Podium, Vue and Indigo (yes Indigo)
        I was under the impression that the new Vray handles grouped meshes better, or is it still doing that wierd disapearing group thing?
        All textures have been applied to both faces, not groups/components.
        http://www.solos-art.com
          Ok, with only one level of grouping it should be fine.
          The original version had some problems where groups would not render at all. Components where fine.
          In SR1.0 it seemed this was fixed, but in SR1.5 things seemed to disappear again. But this time only when you edited a group. Apparently SU doesn't report back that the group changed. But when the file is reloaded it works fine. So it should not be a problem when you just place the vegetation components out there. Only if one where to edit them. But a V-Ray user would most likely be aware of this problem anyway, so I wouldn't worry about that.
            sepo
            Yes it would be nice to have trees and shrubs from Northern hemisphere. Well that is where my interest would be.
            • soloS Offline
              solo
              Technically they are, Most of these are used in Texas (mind you that's like another planet, strange weather, strange landscape and even stranger people/presidents)
              • soloS Offline
                solo
                Here is a flower that is from a temperate climate, anyone from such an environment confirm this?
                Nasturtium
                http://img12.imageshack.us/img12/4372/nastreumrenderei3.jpg
                http://img23.imageshack.us/img23/1844/nastreumrender1mi2.jpg
                • boofredlayB Offline
                  boofredlay
                  I have already started a savings account. I am placing a couple dollars on my computer every day waiting for the release, I hope that will cover it ๐Ÿ˜‰
                    mateo soletic
                    Great plants ๐Ÿ‘ I am hoping for a Mediterranean collection pack.
                    Concept Illustrations
                      Luis Esteves
                      Incredible !! I love these plants !!
                      Great work Solo ๐Ÿ˜ฒ
                      • P Offline
                        pmiller
                        Love Nastursiums. We plant them every spring in SE Pennsylvania and they continue to a hard frost. I believe they grow year round in areas without frost (i.e. California has tons along the ocean up as far as San Francisco). And they taste good.
                        • urgenU Offline
                          urgen
                          ...good low-poly collection Pete! ๐Ÿ‘
                          --pupil forever...------
                          • pbacotP Offline
                            Nice sturtiums, Pete, They look very realistic, especially the leaves. They are a very rangy plant that crawls all over in happy disarray and the flowers tend to be floppy and rarely perfect like this, but this is fine, very fine.
                            • soloS Offline
                              solo
                              Thanks guys, and I noticed they are very rangy, I will try modify them to look less organised.
                              Fern, Adenium, Daffodils and rocks.
                              http://img4.imageshack.us/img4/9770/evenmoreplantszp5.jpg
                              • DanielD Offline
                                Daniel
                                Pete, your work is always amazing. I've a few requests:
                                A larger, denser liriope; they are very popular here, growing about 18" tall and very dense.
                                a hellebore (linten rose)
                                flowering crepe myrtle
                                My avatar is an anachronism.
                                  rcossoli
                                  excellent job Pete!!!, something normal in you, the truth you can buy these plants is because they are very good and in sketchup is not always easy with vegetation so real, I guess that tell us where you can buy, grating
                                  THREEDIMENSIONSWEB dot COM
                                    steelers05
                                    Solo these look great, I havent completely read through this thread so I apologize if I am repeating this question, but what did you use to map the textures? Im pretty sure photoshop cs4 can handle mapping on 3d objects, as well as zbrush...did you use any of these or was it in 3ds max?
                                      Roger
                                      Solo I am doing a photography collection of desert flora. Any interest or too limited in its reach.
                                      http://www.azcreative.com
                                      • EarthMoverE Offline
                                        EarthMover
                                        Pete, I know quite a few landscape designers and architects that will jump on your collection. If I may add my requests....
                                        More ornamental grasses. Specifically Miscanthus Gracillimus Maiden Grass, Karl Forester Feather Reed Grass and Karley Rose Fountain Grass. These are staples in northeast landscape design and something I'm currently lacking in my collection.
                                        Just to give you a run down of what LA's in my zone (6b) would be looking for:
                                        Perennial staples - Rudbeckia (Black Eyed Susan), Echinacea (Coneflower), Perovskia (Russian Sage), Shasta Daisy, Lavendula, Gaillardia (Blanket Flower), Autumn Joy Sedum, Hosta, Phlox, Daylilly, Huechera (Coral Bell) & Dianthus.
                                        Evergreen Shrub staples - Boxwood, Otto Luyken Cherry Laurel, Schipkaensis Laurel, Ilex Glabra (Inkberry Holly), Pieris, PJM Rhodedendron
                                        Flowering Shrub staples - Spirea, Knockout Rose, Hydrangea, Crape Myrtle, Weigelia, Lilac, Forsythia, Viburnum
                                        Other things would be ornatmental trees such as weeping cherry, dogwood and flowering crabapple
                                        Dwarf and weeping conifers such as globe blue spruce, hinoki cypress, weeping blue atlas cedar, weeping alaskan cedar
                                        Those are just a few of the many I use all the time in my designs. Even having just a few of these in 3D format would be worth the purchase of the collection.
                                        What you posted so far would not be of much benefit to a landscape designer in my climate, except as use in annual gardens and planters, with the exception of the liriope and ferns.
                                        Overall A+ on the modeling. I think it would behoove you to also release this collection in .vob format for Vue users, perhaps on cornicopia3d.com
                                        Content Creator at Skapeup
                                        • soloS Offline
                                          solo
                                          Thanks again guys.
                                          Adam, that's quite a list, you giving me room for a few collections there.
                                          The first collection is nearing an end, here are a few more:
                                          Daffodils (re-done), English meadow flowers, Hydreangeas and some generic wild flowers.
                                          http://img25.imageshack.us/img25/2882/solocollection2wa0.jpg
                                          And the water lily.
                                          SU output
                                          http://img21.imageshack.us/img21/6522/waterlilysuwi7.jpg
                                          Vue render
                                          http://img21.imageshack.us/img21/4169/waterlilymr1.jpg
                                            steelers05
                                            Solo did u see my previous post? Still really curious how u mapped the textures
                                            • 6
                                            • 3 / 6
