    ๐Ÿšจ Skimp | 25% Off until March 30 Buy Now
    Garden collection
    101 Posts 42 Posters 25.0k Views 42 Watching
    • soloS Offline
      Thanks guys.
      Dirk, I have not released it yet as I am still completing it.
      I saw in one of your gallery threads you were using very high poly vegetation for you photoreal rendering, what I am hoping here is a collection of photoreal vegetation thats lower poly and that renders perfectly with every engine including Vray that does not use .png's too well. All my textures will be .jpg's (optimised) so no alpha mapping needed, and they will all be 3D so no shadow issues and alignment issues. I also wanted a product that straight SU users could use that looked great and even use them in animations (face me's just don't cut it)
      I am hoping to wrap it up soon and have it available by month end, I am just trying to figure out how to distribute it and what a fair price would be, I want it to be a fair price for both the user and for the amount of work I've put into it with modeling and texture creation.
        lightburn
        wow! just wow. ๐Ÿ‘
          Are you referring to that V-Ray requires you to load an alpha channel bitmap for transparency?
          I'm really interested in this collection of yours Solo. I sorely need some vegetation which doesn't kill SU.
          • soloS Offline
            Thomthom, yeah, thats what I mean. I never got around to trying clipmaps during my Vray trial but heard a lot of chatter on these forums about the seperate alpha channel issue, so these will not require any fancy mapping as they are ready to render. Whats even better is the texturing is good enough to not even render as straight SU output will be photoreal as the textures are from photos.
              I see that you are adding a lot of tropical/subtropical flora to this collection. Any chance for more "temperate" vegetation?
                stereofidelic
                those are just great.
                • soloS Offline
                  Csaba, I asked for folks to make requests, do you have anything in mind for this collection? I am making this a garden collection so if you need any shrubs, plants or flowers from your zone let me know.
                  I will see how things go with this collection and if things work well I will do other stuff like Trees by zone or whatever the market wants.
                  I was asked for interior plants too as 2D png images do not render great indoors, so that's another collection, I will however not include the Vases as Vases are based on the interior design and choice so my plants will be able to be used with any vase the users chooses.
                    That's an interesting question. What kind of vegetation are you making? Any particular climate? Will you be doing packages for different climates?
                    I do visualisation work for an architectural office where we operate only in Norway, so my interest for vegetation would be limited to vegetation which occurs in Northern Europe.
                    By the way, can you give some example face/edge count for some of the examples you've posted?
                    • soloS Offline
                      Sure...
                      Here is a complex model, the Sweet potato vine, model is 141kb (this is straight SU image with edges on)
                      http://img16.imageshack.us/img16/9656/edgecountyb4.jpg
                        Why so many groups? Are they deeply nested?
                        Reason I ask, is that V-Ray will take longer to parse scenes which has many deeply nested groups/components. Also, is all material applied to the geometry or the groups.
                        V-Ray will also slow down, quite notably very quickly, from materials applied to groups or components. Just a FYI.
                        • soloS Offline
                          Every stem and every leaf is a seperate group, only one level down (Component --> 86 groups)
                          Renders fast in Podium, Vue and Indigo (yes Indigo)
                          I was under the impression that the new Vray handles grouped meshes better, or is it still doing that wierd disapearing group thing?
                          All textures have been applied to both faces, not groups/components.
                            Ok, with only one level of grouping it should be fine.
                            The original version had some problems where groups would not render at all. Components where fine.
                            In SR1.0 it seemed this was fixed, but in SR1.5 things seemed to disappear again. But this time only when you edited a group. Apparently SU doesn't report back that the group changed. But when the file is reloaded it works fine. So it should not be a problem when you just place the vegetation components out there. Only if one where to edit them. But a V-Ray user would most likely be aware of this problem anyway, so I wouldn't worry about that.
                              sepo
                              Yes it would be nice to have trees and shrubs from Northern hemisphere. Well that is where my interest would be.
                              • soloS Offline
                                Technically they are, Most of these are used in Texas (mind you that's like another planet, strange weather, strange landscape and even stranger people/presidents)
                                • soloS Offline
                                  Here is a flower that is from a temperate climate, anyone from such an environment confirm this?
                                  Nasturtium
                                  http://img12.imageshack.us/img12/4372/nastreumrenderei3.jpg
                                  http://img23.imageshack.us/img23/1844/nastreumrender1mi2.jpg
                                  • boofredlayB Offline
                                    boofredlay
                                    I have already started a savings account. I am placing a couple dollars on my computer every day waiting for the release, I hope that will cover it ๐Ÿ˜‰
                                      mateo soletic
                                      Great plants ๐Ÿ‘ I am hoping for a Mediterranean collection pack.
                                      Concept Illustrations
                                        Luis Esteves
                                        Incredible !! I love these plants !!
                                        Great work Solo ๐Ÿ˜ฒ
                                          pmiller
                                          Love Nastursiums. We plant them every spring in SE Pennsylvania and they continue to a hard frost. I believe they grow year round in areas without frost (i.e. California has tons along the ocean up as far as San Francisco). And they taste good.
                                          • urgenU Offline
                                            urgen
                                            ...good low-poly collection Pete! ๐Ÿ‘
                                            --pupil forever...------
                                            • 3 / 6
