    A question about. SKM
    3 Posts 2 Posters 532 Views 2 Watching
      rcossoli
      Hello everyone, I wanted to ask a question about the files in. SKM, and knowing which is the way to create them, if they can be created so simply because
      THREEDIMENSIONSWEB dot COM
        SKM is actually a renamed ZIP file (if you re-rename it to zip,you can open it and see its content -such as the image file itself).
        Anyway, to create an skm file, you don't need to do anything than import an image (ormodify an existing material) then create a new material from it and svae it somewhere on your HD.
          rcossoli
          thanks a lot!!
