    Can we create parametric in new component by ruby script ?
    5 Posts 3 Posters 517 Views 3 Watching
    • H Offline
      Heven7_floor
      I have download SU7 free version, and see useful capability of parametric component ,but I have only free version 😒 ,Are there any way to create or edit parametric component by ruby script ? ❓
        RickW
        It is theoretically possible, but I don't know if anyone has tried yet.
        RickW
        www.smustard.com
        • H Offline
          Heven7_floor
          thank for your answer RickW πŸ˜‰ , I enter here every day to see answer, I just start to learning with SU ruby script,I thing that my some query might be silly to expertise, thanks you for your patience with new face πŸ˜„
            remus
            Id guess there might be legal issues with a script that let you create your own DCs, as it is effectively bypassing the need to buy the pro version.
            I suspect it is a matter of degrees, though, and would depend a lot on what you wanted to do.
            • H Offline
              Heven7_floor
              Hi remus ! 😎
              Due of query about component parameter has post in SCF , which had occured since I play in SU6, I make several component to compose/assembly for piping drawing, and I spent time to create various size of fitting , and though that may wasted time, due it why so I try to learn in deep for ruby script
              the reason that I attempt to spent lot of time into SU and pause my default CAD software(expensive cost of Autodesk πŸ‘Š ), I want to seek potential of SU to decision making for cost saving substitution
              I don't thing far as that, and there are several feature different between Pro & free version,however there are may advantage in Pro version if we need it really
              so I ever learned a little bit of business and know why google have SU in Pro and Free version.
              even I have the way to access its ability ,I don't sure that it will be enough reason that I shall purchase SU in Pro version πŸ˜‰
