Can we create parametric in new component by ruby script ?
I have download SU7 free version, and see useful capability of parametric component ,but I have only free version
,Are there any way to create or edit parametric component by ruby script ?
It is theoretically possible, but I don't know if anyone has tried yet.
thank for your answer RickW
, I enter here every day to see answer, I just start to learning with SU ruby script,I thing that my some query might be silly to expertise, thanks you for your patience with new face
Id guess there might be legal issues with a script that let you create your own DCs, as it is effectively bypassing the need to buy the pro version.
I suspect it is a matter of degrees, though, and would depend a lot on what you wanted to do.
Hi remus !
Due of query about component parameter has post in SCF , which had occured since I play in SU6, I make several component to compose/assembly for piping drawing, and I spent time to create various size of fitting , and though that may wasted time, due it why so I try to learn in deep for ruby script
the reason that I attempt to spent lot of time into SU and pause my default CAD software(expensive cost of Autodesk
), I want to seek potential of SU to decision making for cost saving substitution
I don't thing far as that, and there are several feature different between Pro & free version,however there are may advantage in Pro version if we need it really
so I ever learned a little bit of business and know why google have SU in Pro and Free version.
even I have the way to access its ability ,I don't sure that it will be enough reason that I shall purchase SU in Pro version
