    TV space for two...
    12 Posts 7 Posters 894 Views 7 Watching
    • F Offline
      fymoro
      Hi, here are a real project that I have stated since 3 days, it is an improvement of a old house in south UK.
      I have started by the "TV space" for two as requested by owner.
      Just some thing about Vray 1.0. It is so difficult to do nice spot light effect, I have found the way to do IES Faked effect but, I think that it look very faked... And you ?
      Is Vray 1.5 is better for that ? I it is the case, I will purchase it.
      Thanks for your comment, Fred.
      Vray 1.0 render time 1h30 Distributed rendering with two quad processoor
      http://www.thearender.com/cms/index.php/news/featured-artists/137-frederic-yves-moro.html
      • P Offline
        puck
        Great work Fred. I particularly like the back wall. Did you simply use a bump map texture on a flat surface?
        • F Offline
          fymoro
          Thank Puck,
          I have not used a Bump, but a low displacement map.
          Bye, Fred
          • F Offline
            fymoro
            If someone like the stone back wall, I would like to share it , so I have just upload it on http://www.material-db.com
            Old Stone Wall is the name.
            enjoy !!
              sepo
              Very nice image. Do you mind sharing technique of your fake IES?
                materialdb
                good looking image!
                thanks again for sharing!
                free vismat materials: http://www.material-db.com
                • F Offline
                  fymoro
                  Thanks Sepo,
                  It is ok for me to share, and I think that you can apply that to all renderer plug-in.
                  The faked "IES Effect" is very easy to apply, but very tiring to regulate.
                  In fact, it is like adding a filter in front of your light. ( use this attached map for filter)
                  This map must be apply on a circle or a square in front of your spot-light and very important, you must use the same map as transparency map. You must add also a Light inside the spot light. I attach the model here.
                  After, when you have your effect, if you want more or less intensity, regulate the light, and also the transparency parameter.
                  I hope that it is useful for you. Bye
                  Filter map
                  Model Spot light
                    sepo
                    Thank you very much for the IES. I have tried to download the old stone wall but it would not let me to do. For whatever reason is asking me to upload that very wall.
                    • F Offline
                      fymoro
                      Another view
                        ScottPara
                        Fred,
                        Fantistic render! My only crits (all be it very small crits) would be:
                        The TV needs to be somewhat brighter (emmisive texture?)
                        The vase on the shelf looks just about to fall 😄
                        I would get rid of the speakers to each side of the tv (go for a larger lcd screen) and mount small satellite speakers in the corner of the room. (personal preference).
                        The back wall texture looks VERY good and looks far better than a bump map. Displacements are the way to go (if you have the time to wait and the computer to handle them).
                        I have Vray 1.5 and the improvements are very good and many. It handles materials far better now (no more linking) and I feel it is a bit quicker as well. The emmisive textures and lighting have been improved as well. Well worth the upgrade price in my opinion.
                        Check your PM's as I finally answered your questions 😄
                        Scott
                        Love the fact that some HATE my avatar.....
                        • F Offline
                          fymoro
                          Thanks Scott and Modelhead,
                          You are right, I will arange some stuff, and certainly change by real armchairs...
                          Bye.
                          • boofredlayB Offline
                            boofredlay
                            Wonderful image Fred.
