    Experinced Rhino Users - recommended export/import workflow?
    2 Posts 2 Posters 501 Views 2 Watching
    • JClementsJ
      JClements
      I was wondering if there is anyone here who uses Rhino 4 and SU6 or SU7. I have not used Rhino in at least 3 years.
      How good are the import-to-Rhino and export-from-Rhino filters (is there an .skp export option or is there a plugin or what other export formats could you recommend)?
      Any other advice with regards to work flow.
      I have old Rhino Models (done in versions 2 and 3) I may want to try and convert for use in SU.
      Regards, John
      • soloS
        solo
        John
        I can batch convert for you if you need.
        http://www.solos-art.com
