    American Flag Mapping
    21 Posts 6 Posters 3.7k Views 6 Watching
    • david_hD
      david_h
      I am doing a flag for a project. Obviously I want to have it look natural, windblown etc.
      Ihave used FFD, SubSmooth and UV tools for mapping. Any comments on how I can it better? Especially the mapping part?
      thx,
      David
      EDIT . .. I added the state flag at well. I think that turned out all right. but when I rendered it the seal didn't read! WHADDUP with That!??
      • david_hD
        david_h
        I'm on a flag kick here. . .This Union Jack didn't map all that bad. There's a glitch in the second image. . .Check out the width of the top center red band.
        • GaieusG
          You probably used projected texture, didn't you?
          • david_hD
            david_h
            Shouldn't I have? That's what I thought I was s'posed to do!
            Also, I did a French flag last night and it worked out fine. Rather than just painting blue white red using the mat'ls pallette I projected an image. Drew up fine, but didn't render in podium. Same problem with the UTAH state flag. just a blue field. I don't get it. Why do some maps render and others don't?
            • soloS
              solo
              David
              Check your source image, I bet it's a .bmp or .tif.
              Change it to .jpg or .png, and if it has weird characters in the name rename to simple.
              Quick flag using sds.
              http://img339.imageshack.us/img339/4121/flagvueqj6.png
              http://www.solos-art.com
              • P
                pav_3j
                I'm on a flag kick here. . .This Union Jackdidn't map all that bad. There's a glitch in the second image. . .Check out the width of the top center red band.
                Sorry to be a geek, but unless it's on a boat, it can't be called the Union Jack, anything else is just a plain old Union Flag.
                Wicked model though!
                Pav
                Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
                • david_hD
                  david_h
                  Your geekness is excused. I actually kinda knew that. . .(not! 😳 ) but we cuzzins over here on this side of the pond just call it the Union Jack regardless.
                  thanks for the feedback Pete. .. I will check the image type. I suspected that was it.
                  • david_hD
                    david_h
                    looks like that was it. . . Thanks! πŸ˜†
                    Now our state just needs to come up with a better design.
                    • david_hD
                      david_h
                      This is just too fun!
                      • GaieusG
                        Shouldn't I have [i.e. projected the UJ]? That's what I thought I was s'posed to do!
                        No, I mean that's what I'd've done as well. Maybe if the big wave wasn't right in the middle of the flag, it wouldn't be so apparent.
                        Cool game however! πŸ‘
                        • david_hD
                          david_h
                          It occured to me thru all of this that perhaps the most efficient way to do with is with a Face Me clipmap and call it good. although these flags are only about 250K each.
                          Pause and discuss. . . πŸ’š
                          • GaieusG
                            Face me is a good idea - this way you can make sure that the wind seems to be blowing from the same direction for all the flags (should you decide to use more in a scene).
                            • david_hD
                              david_h
                              wind is a consideration and also. . .making these flags is just too much fun!
                              • urgenU
                                urgen
                                ...David,select flag's groop and use Soap Skin Bubble skript (press "Restart FormFinding")
                                http://www.tensile-structures.de/sb_software.html
                                ...just too much fun!. πŸ˜‰ πŸ˜„
                                flag.skp
                                --pupil forever...------
                                • soloS
                                  solo
                                  Hey David, how about an overkill.
                                  I give you the curtain flag.
                                  http://img223.imageshack.us/img223/23/largecurtain1dividedod0.jpg
                                  http://img294.imageshack.us/img294/8475/largecurtain1flagaa4.jpg
                                  • david_hD
                                    david_h
                                    I for the life of me can't figure out how to get Soap Skin to work. I don't find the help site much help either. Anybody wanna give a tut!
                                    Solo. . .you--as usual. . .are da man.
                                    πŸ’š
                                    • urgenU
                                      urgen
                                      ...two small video...
                                      SSB animation.rar
                                      flag.rar
                                      ... Look more here...
                                      http://groups.google.com/group/Ruby-API/browse_thread/thread/982c56fae94d3537/fececa1a9d219f24?lnk=gst#fececa1a9d219f24
                                      ...PavAks and urgen the same person πŸ˜‰ πŸ˜„
                                      • david_hD
                                        david_h
                                        Thanks Urgen. You know I tried using SSB as you did but I dont get the results. when I select a rectangle and skin it. It shows a grid, but then when I apply a pressure, it asks for a selection first but doesn't maintain it or whatever and the grid disappears . .. it's all very confusing.
                                        D
                                        • urgenU
                                          urgen
                                          Thanks Urgen. You know I tried using SSB as you did but I dont get the results. when I select a rectangle and skin it. It shows a grid, but then when I apply a pressure, it asks for a selection first but doesn't maintain it or whatever and the grid disappears . .. it's all very confusing...
                                          ....Strange πŸ˜• .... Can be ask about it the author?
                                          • boofredlayB
                                            boofredlay
                                            David, I made a tutorial for Jeff (Click Draw) a while back. Check it out and see if it helps.
                                            http://www.sketchucation.com/forums/scf/viewtopic.php?p=117613#p117613
                                            • 1 / 2
