    American Flag Mapping
    21 Posts 6 Posters 3.6k Views 6 Watching
    • david_hD
      david_h
      Shouldn't I have? That's what I thought I was s'posed to do!
      Also, I did a French flag last night and it worked out fine. Rather than just painting blue white red using the mat'ls pallette I projected an image. Drew up fine, but didn't render in podium. Same problem with the UTAH state flag. just a blue field. I don't get it. Why do some maps render and others don't?
      • soloS
        David
        Check your source image, I bet it's a .bmp or .tif.
        Change it to .jpg or .png, and if it has weird characters in the name rename to simple.
        Quick flag using sds.
        http://img339.imageshack.us/img339/4121/flagvueqj6.png
        • P
          pav_3j
          I'm on a flag kick here. . .This Union Jackdidn't map all that bad. There's a glitch in the second image. . .Check out the width of the top center red band.
          Sorry to be a geek, but unless it's on a boat, it can't be called the Union Jack, anything else is just a plain old Union Flag.
          Wicked model though!
          Pav
          Just won the 'Who is Least Competitive Championships' where trying to win will make you lose. Trying to lose makes you win which makes you lose. Not trying at all makes you lose which makes you win which makes you lose.
          • david_hD
            david_h
            Your geekness is excused. I actually kinda knew that. . .(not! 😳 ) but we cuzzins over here on this side of the pond just call it the Union Jack regardless.
            thanks for the feedback Pete. .. I will check the image type. I suspected that was it.
            • david_hD
              david_h
              looks like that was it. . . Thanks! πŸ˜†
              Now our state just needs to come up with a better design.
              • david_hD
                david_h
                This is just too fun!
                • GaieusG
                  Shouldn't I have [i.e. projected the UJ]? That's what I thought I was s'posed to do!
                  No, I mean that's what I'd've done as well. Maybe if the big wave wasn't right in the middle of the flag, it wouldn't be so apparent.
                  Cool game however! πŸ‘
                  • david_hD
                    david_h
                    It occured to me thru all of this that perhaps the most efficient way to do with is with a Face Me clipmap and call it good. although these flags are only about 250K each.
                    Pause and discuss. . . πŸ’š
                    • GaieusG
                      Face me is a good idea - this way you can make sure that the wind seems to be blowing from the same direction for all the flags (should you decide to use more in a scene).
                      • david_hD
                        david_h
                        wind is a consideration and also. . .making these flags is just too much fun!
                        • urgenU
                          urgen
                          ...David,select flag's groop and use Soap Skin Bubble skript (press "Restart FormFinding")
                          http://www.tensile-structures.de/sb_software.html
                          ...just too much fun!. πŸ˜‰ πŸ˜„
                          flag.skp
                          --pupil forever...------
                          • soloS
                            Hey David, how about an overkill.
                            I give you the curtain flag.
                            http://img223.imageshack.us/img223/23/largecurtain1dividedod0.jpg
                            http://img294.imageshack.us/img294/8475/largecurtain1flagaa4.jpg
                            • david_hD
                              david_h
                              I for the life of me can't figure out how to get Soap Skin to work. I don't find the help site much help either. Anybody wanna give a tut!
                              Solo. . .you--as usual. . .are da man.
                              πŸ’š
                              • urgenU
                                urgen
                                ...two small video...
                                SSB animation.rar
                                flag.rar
                                ... Look more here...
                                http://groups.google.com/group/Ruby-API/browse_thread/thread/982c56fae94d3537/fececa1a9d219f24?lnk=gst#fececa1a9d219f24
                                ...PavAks and urgen the same person πŸ˜‰ πŸ˜„
                                • david_hD
                                  david_h
                                  Thanks Urgen. You know I tried using SSB as you did but I dont get the results. when I select a rectangle and skin it. It shows a grid, but then when I apply a pressure, it asks for a selection first but doesn't maintain it or whatever and the grid disappears . .. it's all very confusing.
                                  D
                                  • urgenU
                                    urgen
                                    Thanks Urgen. You know I tried using SSB as you did but I dont get the results. when I select a rectangle and skin it. It shows a grid, but then when I apply a pressure, it asks for a selection first but doesn't maintain it or whatever and the grid disappears . .. it's all very confusing...
                                    ....Strange πŸ˜• .... Can be ask about it the author?
                                    • boofredlayB
                                      boofredlay
                                      David, I made a tutorial for Jeff (Click Draw) a while back. Check it out and see if it helps.
                                      http://www.sketchucation.com/forums/scf/viewtopic.php?p=117613#p117613
                                      • david_hD
                                        david_h
                                        I just had a "D'oh!" moment again. (I get those a lot)
                                        I was goofing up at the Skin step. I guess it would draw a "PREVIEW" Skin but in order for it to take, I had to hit enter again and it would "Generate" it. and from there I could draw the bulgies. Thanks. That helped a lot.
                                        Now back to making Flags and Pennants!
