    Deck and Pool
    17 Posts 6 Posters 1.5k Views 6 Watching
    • EarthMoverE Offline
      EarthMover
      Here's a deck and pool design that I rendered in Vue 7, with some post process work in PS. Design was done in autocad by a colleague, I just did part of the SU modeling and the render work. Looking for some comments and critiques as I think I've been looking at it too long!
      http://img232.imageshack.us/img232/3987/meyersmodelsketchy2qv6.jpg
      http://img232.imageshack.us/img232/1447/myersvuerenderfinal2dm5.jpg
      Content Creator at Skapeup
      • boofredlayB Offline
        boofredlay
        Looks great. The water is fantastic.
        The patio texture is a bit too bright in areas for my taste however. The reflection on the lower windows and glass door do not match the surroundings. The roof texture is odd and it is tiling quite a bit. I would also loose the people, they distract from the design, especially being ghosted like you have them. But that is just my opinion.
        Your landscaping and background trees are very very good.
          remus
          Perhaps a slightly darker/more weathered texture for the decking. A displacement map might look good on the roof, aslthough im not sure if vue supporst them.
          Overall very nice though, the recipient could hardly not be pleased πŸ˜„
            EarthMover
            Thanks guys. Exactly the kind of advice I was looking for.
              sepo
              Diffuse glow too strong, saturation too high.
                EarthMover
                Toned down the glow and added a water effect.
                http://img150.imageshack.us/img150/6972/myersanimatedwater2ac0.gif
                  sepo
                  Looks much better.... πŸ‘ Like the moving water....(squirls?)
                  • Gus RG Offline
                    Gus R
                    Adam, here's my two cents.
                    1. Change the sky background to a bright blue that somewhat matches the pool water. The pool water would indicate a clear sky with a blue that is nearly equal to the sky.
                    2. Remove the flock of egrets. They look a little busy.
                    3. Figures could be replaced. The man's legs seems to be fading and the woman looks a bit flat and showing too much leg.
                    4. The glass effect at the turret doesn't match the rest of the house. The lower sliding door is also showing a grass reflection. Might want to add one step at the bottom of this door.
                    5. Use a greener grass for the field in the background.
                    πŸ€“
                    www.instagram.com/gusrobatto/
                    www.facebook.com/gusrobatto
                      remus
                      For the NPR renders: hide the lines beneath the surface, spoils the illusion somewhat otherwise. A bit more colour wouldnt go amiss in the first one, either.
                        EarthMover
                        Thanks Gus. I agree with everything you said. Not sure what's doing with the reflections. They all have the same material applied.
                        Sepo - water is done with this software - http://www.nufsoft.com/naturestudio.php Took 5 minutes including .gif export
                        The client wanted to see some NPR WC styles, so this is what I came up with. Straight SU outputs and PS layering. Any opinions on these?
                        http://img230.imageshack.us/img230/1100/myersnpr1sr2.jpg
                        http://img527.imageshack.us/img527/3200/myersnpr2uv5.jpg
                          EarthMover
                          Thanks Remus. Good advice....I'll try and lighten the lines a bit.
                            sepo
                            Thanks for the heads up πŸ‘
                            • Gus RG Offline
                              Gus R
                              That last NPR is really nice.
                              Adam, for the reflection materials, check your face orientation. You know, toggle to monochrome and see if all faces are white, etc. If the glass has a thickness to it I think the faces still have to remain in the same order.
                                EarthMover
                                Tried my hand at another NPR render using a different angle of the same project. This time I used a quick Podium output with some water reflection as my base and did a bunch of hand work and layer masking in photoshop. I wanted the final result to be legible, but dirty at the same time. Any thoughts....advice?
                                Raw Podium output
                                http://img232.imageshack.us/img232/1156/200901201754016m28ssz6.png
                                Watercolor render
                                http://img136.imageshack.us/img136/4577/myers2wcpoolshot2bj7.jpg
                                • Gus RG Offline
                                  Gus R
                                  Adam, the water and the blue look pretty much fantastic. The watercolor version gives it a feeling of a heated pool on a cold day.
                                    EarthMover
                                    Thanks Gus. Here's another set I was playing with.
                                    Podium Render with slight PP
                                    http://img135.imageshack.us/img135/2738/podiumsideview2rp3.jpg
                                    Photoshop in DWC style
                                    http://img232.imageshack.us/img232/4657/sideviewrenderwc2rh0.jpg
                                    • Gus RG Offline
                                      Gus R
                                      Adam, these last two are winners. Might want to add a backdrop of sorts on the first one. πŸ˜„
                                      Nice pool! Don't see many around these parts.
