    Deck and Pool
    17 Posts 6 Posters 1.7k Views 6 Watching
      sepo
      Diffuse glow too strong, saturation too high.
      • EarthMoverE Offline
        EarthMover
        Toned down the glow and added a water effect.
        http://img150.imageshack.us/img150/6972/myersanimatedwater2ac0.gif
        Content Creator at Skapeup
          sepo
          Looks much better.... πŸ‘ Like the moving water....(squirls?)
          • Gus RG Offline
            Gus R
            Adam, here's my two cents.
            1. Change the sky background to a bright blue that somewhat matches the pool water. The pool water would indicate a clear sky with a blue that is nearly equal to the sky.
            2. Remove the flock of egrets. They look a little busy.
            3. Figures could be replaced. The man's legs seems to be fading and the woman looks a bit flat and showing too much leg.
            4. The glass effect at the turret doesn't match the rest of the house. The lower sliding door is also showing a grass reflection. Might want to add one step at the bottom of this door.
            5. Use a greener grass for the field in the background.
            πŸ€“
            www.instagram.com/gusrobatto/
            www.facebook.com/gusrobatto
              remus
              For the NPR renders: hide the lines beneath the surface, spoils the illusion somewhat otherwise. A bit more colour wouldnt go amiss in the first one, either.
                EarthMover
                Thanks Gus. I agree with everything you said. Not sure what's doing with the reflections. They all have the same material applied.
                Sepo - water is done with this software - http://www.nufsoft.com/naturestudio.php Took 5 minutes including .gif export
                The client wanted to see some NPR WC styles, so this is what I came up with. Straight SU outputs and PS layering. Any opinions on these?
                http://img230.imageshack.us/img230/1100/myersnpr1sr2.jpg
                http://img527.imageshack.us/img527/3200/myersnpr2uv5.jpg
                  EarthMover
                  Thanks Remus. Good advice....I'll try and lighten the lines a bit.
                    sepo
                    Thanks for the heads up πŸ‘
                    • Gus RG Offline
                      Gus R
                      That last NPR is really nice.
                      Adam, for the reflection materials, check your face orientation. You know, toggle to monochrome and see if all faces are white, etc. If the glass has a thickness to it I think the faces still have to remain in the same order.
                        EarthMover
                        Tried my hand at another NPR render using a different angle of the same project. This time I used a quick Podium output with some water reflection as my base and did a bunch of hand work and layer masking in photoshop. I wanted the final result to be legible, but dirty at the same time. Any thoughts....advice?
                        Raw Podium output
                        http://img232.imageshack.us/img232/1156/200901201754016m28ssz6.png
                        Watercolor render
                        http://img136.imageshack.us/img136/4577/myers2wcpoolshot2bj7.jpg
                        • Gus RG Offline
                          Gus R
                          Adam, the water and the blue look pretty much fantastic. The watercolor version gives it a feeling of a heated pool on a cold day.
                            EarthMover
                            Thanks Gus. Here's another set I was playing with.
                            Podium Render with slight PP
                            http://img135.imageshack.us/img135/2738/podiumsideview2rp3.jpg
                            Photoshop in DWC style
                            http://img232.imageshack.us/img232/4657/sideviewrenderwc2rh0.jpg
                            • Gus RG Offline
                              Gus R
                              Adam, these last two are winners. Might want to add a backdrop of sorts on the first one. πŸ˜„
                              Nice pool! Don't see many around these parts.
