    Greeble
    9 Posts 6 Posters 961 Views 6 Watching
    • boofredlayB Offline
      boofredlay
      I have always loved greeble renderings so I decided to try one of my own.
      Rendered in Podium. Hope you like πŸ˜„
      • soloS Offline
        solo
        Hey Eric that's cool looking, did you use 'protrude' plugin? or is there another greeble ruby floating around that I do not have?
        http://www.solos-art.com
          boofredlay
          Yes the protrude. I also have over 100 omni's at about 14 in there.
          Edit: After using protrude I manually moved the surfaces to different levels.
            hehe πŸ’š
            Seems you can have similar result with that in one click πŸ˜‰
              sepo
              Looking good Eric. πŸ‘
                boofredlay
                Thanks sepo.
                Pilou, I have that and never used it, thanks! This will make it easier if I decide to do a larger area as the one I did was pretty small then copied many times over.
                • spenceS Offline
                  spence
                  Looks cool Eric. Makes me want to start using Podium again, for some reason or another I have not been doing any work that inspires me to "Podiumize" it.
                  Spence
                    Jim
                    hehe πŸ’š
                    You can do some neat things with the offset and taper options of protrude.
                      Sure your Ruby will be a classic one! 😎
                      I don't see random inside? ❓ (like your above)
