Greeble
I have always loved greeble renderings so I decided to try one of my own.
Rendered in Podium. Hope you like
Hey Eric that's cool looking, did you use 'protrude' plugin? or is there another greeble ruby floating around that I do not have?
Yes the protrude. I also have over 100 omni's at about 14 in there.
Edit: After using protrude I manually moved the surfaces to different levels.
hehe
Seems you can have similar result with that in one click
Looking good Eric.
Thanks sepo.
Pilou, I have that and never used it, thanks! This will make it easier if I decide to do a larger area as the one I did was pretty small then copied many times over.
Looks cool Eric. Makes me want to start using Podium again, for some reason or another I have not been doing any work that inspires me to "Podiumize" it.
hehe
You can do some neat things with the offset and taper options of protrude.
Sure your Ruby will be a classic one!
I don't see random inside?
(like your above)
