Ruby script matte for photoshop
14 Posts 9 Posters 1.6k Views 9 Watching
    crosswaves
    Is there a ruby script that will color the 6 faces of a cube different colours, or a complex model. I would then export the file in 2d to photoshop and create simple mattes from the colored faces for painting.
      Hmm, there is a big difference between a simple model and a complex one. Also, would the model be built specifically to be output to Photoshop?
      I do stuff like this regularly, but I always know before hand that my model is going to photoshop to be enhanced so I only add bright, contrasting colors so that they export well to photoshop and I can separate them there easily with the magic wand selection tool. Is that sort of what you have in mind?
      I don't think there is a ruby that does that automatically. Plus, how would it know how to color what objects? A simple is easy if you just want each face colored something different. But a complex model is another story where you probably don't want the color divided up by face, but rather by object. I do that all by hand. its very fast going.
      Is that anything like what you're thinking of?
      Chris
      All my Plugins I've written
        I just made a script for Free Agent that would make all materials black, except the selected material which is made white. That makes for a way to render out an material mask layer.
        Not quite what you asked for, but might it be of use?
        • K Offline
          kwistenbiebel
          That's an excellent idea!
          Render freaks love this for compositing and editing their output in Photoshop.
          Any chance you'd make that script public?
            Stinkie
            +1!
              Ok, it's posted. http://www.sketchucation.com/forums/scf/viewtopic.php?f=180&t=15790
              (Sorry for bringing this thread somewhat off-topic.)
              • P Offline
                plot-paris
                this may go a bit far...
                but is it possible to write a script, that exports a batch of alpha-maps, one for each material? if you have faces with textured materials it sometimes can be quite difficult to select it with the magic wand. with such a pile of alpha-maps it would be a lot easier...
                  Yes. that is possible.
                  but I'm not sure if this is what the OP wants. He was talking about the 6 sides of a cube. Not sure if these faces had separate faces to begin with. And I'm not sure how it's mean to work for a complex model.
                  • P Offline
                    plot-paris
                    yes, true. my idea is a completely new thing and may be a bit off topic hear.
                    with complex models the 6 sided colouring could really be quite tricky. what happens with curved surfaces for example?
                    • E Offline
                      Ecuadorian
                      OP:
                      You have SU Pro, which can export to Piranesi. Why not give it a try?
                      -Miguel Lescano
                      • G Offline
                        gaganraj
                        alpha masks would be HUGE addition. I am constantly needing to separate my content after a vray render and have to make sloppy selections in photoshop. I second plot-paris's request / suggestion!
                          crosswaves
                          Thank you for all your suggestions. My intention is to export primarily to Photoshop, so I can produce quick colour illustrations. Currently I manually paint each surface in SketchUp with bright or contrasting colours,before I export a 2d file. I can produce a mask of the surface in Photoshop it is just slow. I had hope some one would have a script that would automate the process in SketchUp. Colour by layer name or entity maybe. The ability to make Alpha masks when exporting would be great. I have looked at Piranes,it looks very complex I will give it a try.
                            So you don't want to mask out materials, but objects or layers? My script shouldn't be too hard to adapt for that. But I just want to make sure first that's what you're after.
                            • X Offline
                              xrok1
                              would it be possible for the script to temporarily make SU ground and sky white/black as well? 😄
                              “There are three classes of people: those who see. Those who see when they are shown. Those who do not see.”
