    Render of project with maxwell render
    16 Posts 12 Posters 3.6k Views 12 Watching
    • F Offline
      fr152
      afters 24 hours of rendering this is the result, it's not perfect but it's still a wip
      http://img177.imageshack.us/img177/9666/magdalenastraat13ape1.th.png
      tips are welcome!! ๐Ÿ˜„
      another link with the same image http://img177.imageshack.us/my.php?image=magdalenastraat13ape1.png
      • soloS Offline
        solo
        At first glance, your textures are tiling, see ground and bricks. Your shrubs/long grass is too green (looks fake) try adjusting the color. the trees could be exchanged for better ones after all Maxwell does not have a Poly issue so why not get more realistic ones.
        Lastly 24 hours!! ๐Ÿ˜ฎ serious?
        http://www.solos-art.com
          remus
          A better texture for the concrete wouldnt go amiss, its tiling pretty badly at the moment.
          • marked001M Offline
            marked001
            i think the issue with the trees..at least the two at the ends...are the clip maps.. make sure you edit that material in the material editor so that it clips the image and you get 'leaves' instead of rectangles... and obviously, a little rotation/randomizing on those three in the middle, wouldnt hurt. good start though..
            http://www.revision21vis.com
            instagram: revi21on
            • olisheaO Offline
              olishea
              get podium lol
              oli
              • FrederikF Offline
                Frederik
                A nice render and model... ๐Ÿ˜‰
                But like others already have said... You can gain much by working more with the materials and textures... ๐Ÿ˜
                I'm really not impressed with the 24 hours render time... In particular not since the render is only 800 x 364...
                With other unbiased render applications (None mentioned, none forgotten...) you could easily achieve equal quality in max 1 hour... ๐Ÿ˜‰
                Cheers
                Kim Frederik
                • StinkieS Offline
                  Stinkie
                  Try to use AGS instead of 'real' glass, if you aren't already.
                    marked001
                    this may have rendered for 24 hours...but i suspect, it didnt change too too much after the 8 hour mark..
                    instagram: revi21on
                    • G Offline
                      gaucho
                      a cloudy sky maybe? i think it gives you a bit more reality and reference...
                      good start!
                      "eat well, stay fit, die anyway..."
                      • F Offline
                        fr152
                        i had to compress the size of the image, normaly it was 2200x1000.
                        I'm working on a new render with more materials and some new textures ...
                        I'll post an update soon!
                        • F Offline
                          fr152
                          no it didn't ๐Ÿ˜•
                          • F Offline
                            fr152
                            i have worked on my project a little bit more ...
                            this is what i got now.
                            http://img5.imageshack.us/my.php?image=rendervanonshuis2003200z.jpg
                            http://img5.imageshack.us/img5/9422/rendervanonshuis2003200z.jpg
                            • majidM Offline
                              majid
                              nice rende r, but too repetative textures , you may work on them in material editor , or a posst pro whit ps, also adding something ( maybe just a 2d picture ) in front of your glass ( and behinde the camera) may make your glass to seem more realastic. and what about 2d bushes? i guess u've ignored them to texture correctly... ๐Ÿ˜„
                              keep good rendering
                                liam887
                                You can cut many hours off your render time if you just do multiple passes instead of rendering everything in one go. For example just render the house, and the cars in different shots and the environment last. Then compile them together in a 2D program. Many people use this technique, over at SFMeshes some models are in the 'Gigabyte' regions so rendering is painfully slow for them. They can cut their render times in half however using this method?
                                VISIT MY ONLINE GALLERY
                                • RichardR Offline
                                  Richard
                                  As Majid suggests there is some nasty tiling in the foreground materials. To avoid this myself I put a dirt map in the MXM and make the tiling say 0.2 (meaning it is 5 times the size of the original map.
                                  You can do it two ways:
                                  1. Add a second BSDF layer to the material and use a dirt map in the 0 reflectance channel, make this BSDF layer fairly low weighted say 10%.
                                  2. Have 2 BSDF layers of the same paving material with one slightly lighter in colour and vary the weight of each layer with a low contrast greyscale noise map.
                                  I will add that you only need to do this setup once as you know - that material can be saved in this format and used again. This is a great way to get use from smaller tiling maps!
                                  Your windows are relflecting too much of the horizon light! To fix this either:
                                  1. Use a HDRI in the reflection channel for environmental setting and/or
                                  2. Make some very low poly buildings for the opposing side of the road to reflect in the window! Make sure though that these are postioned such that they are seen in the reflections from way down the road.
                                  I will often just copy the main geometry of the building (subject) in the scene and flip it to the other side of the road and scale it up or stretch it so it blocks the horizon sun. Fairly simple and painless!
                                  BUILTBRAND.COM.AU
                                    Roger
                                    I would get rid of the converging verticals. In some scenes they might look OK to make a tall building look taller, but in a buliding this low it just does not feel right to me. I would also add some clouds or other atmospherics to the sky. Now it looks like a model photographed in front of a blue background. Also Photograph a runway or large parking lot. The streed needs a little dirt even if the building s are perfect.The foreground needs a car and some tree branches intruding into the frame. You will have plenty of opportunities to enhance you scene, but don't equate pristine sterility with a great render. A great render needs believability and that denotes some natural processes at work.
                                    http://www.azcreative.com
