    How do you align 2D trees with view?
    5 Posts 4 Posters 1.5k Views 4 Watching
    • C
      CurryPork
      How do you make your 2D trees or 2D people to align with your currect screen view no matter where you orbit the model?
      • boofredlayB
        boofredlay
        When you create the component you have a check box for always face camera; check that. If you want it to rotate at the center of a person or tree, click the "set gluing plane" button then place your axis at the center on the ground plane.
        Hope this helps.
        Edit: D'oh, Bruce beat me.
        • GaieusG
          Hi Curry Pork,
          wow, two people beat me, too, while I was typing! 😲
          These are called "Face me" components. I generally create them with a standard front view (Camera menu > Standard views) and align them on the red/blue plane (it could be anything just make sure to face it fully).
          • Then select the item, right click > Make component.
          • Now in the dialog, choose "always face camera" and "shadow always face sun".
          • Now select the "Set component axes" and make sure that the component origin is placed at the feet of the people or trunk of the tree etc.
          • finally make sure that "Replace selection with component" at the bottom is also checked.
            That should be it.
          • C
            CurryPork
            Oh thank you so much. I spent half a day trying to figure this out with no success and it is so easy now. Thanks.
            • boofredlayB
              boofredlay
              I don't know if it will help or not but here is a tutorial I did a while back on creating a 2D "Face Me" tree.
              http://www.sketchucation.com/forums/scf/viewtopic.php?f=18&t=680&start=0&st=0&sk=t&sd=a
