    Request - A modified Tape Measure tool
    7 Posts 4 Posters 1.6k Views 4 Watching
    • JClementsJ Offline
      JClements
      Perhaps there could be a modified Tape Measure tool, where the user could toggle whether they want to create only an Infinite or a Finite with a guide point irregardless if the first click is on a endpoint or elsewhere on an edge?
      Regards, John
      • david_hD Offline
        david_h
        I am having trouble installing this guy.
        Where do the PNGs go? I am not seeing them. Does this go in TOOLS or Plugins?
          Jim
          David,
          You can always get the latest version here.
          Download and unzip the files to the Plugins folder. You should have one file: clinetool.rb and one folder: clinetool which contains the images.
          The default for the plugin is to add contruction points to the end-points. Tap the Ctrl key to toggle this on and off - the cursor will change to reflect which mode it is in.
          It creates a menu item in Draw, and a toolbar button, as Ron mentioned.
          • david_hD Offline
            david_h
            Thanks. I got it now.
            'Preciate it!
              bellwells
              Try this. It puts an yellow pencil icon on your toolbar. Click it and you can draw construction lines.
              Error 404 (Not Found)!!1
              (sketchuptips.blogspot.com)
              Ron
                bellwells
                Jim, I didn't realize you had updated this little gem...Thanks!!!
                Ron
                  JClements
                  Jim, could your script also "pull" parallel infinite lines like the tape measure tool?
