    Great Wheel tutorial....but...
    8 Posts 3 Posters 4.0k Views 3 Watching
      Click Draw
      On the link below, it shows how to make a tire. The method of push pulling up a tapered tread is done too fast. Any idea how ALL the faces were selected and pulled up with a taper?
      Thanks,
      Jeff
      Have I mentioned how much of a laugh I get out of some of the Signatures on here!
      • boofredlayB Offline
        boofredlay
        James is right. Select the offset faces and activate the scale tool. Move the top center grip up, then the bottom center grip up, that is it. Note that this won't work if your object is just 2d as the scale tool will only give you length and width.
          Click Draw
          Thanks James and Eric,
          Appreciate your advise. It worked great. Here's my first wheel. Took a bit longer than it should have but now I know how to do it. It sure was tiring 🤣
          Cheers,
          Jeff
            boofredlay
            Yes, looks great.
              Click Draw
              Thanks guys...
              • soloS Offline
                solo
                Jeff
                I have never made a tire before (usually just use an image with displacement) however i decided to give it a go. I made a video as i did it so it's not 'practiced' so it wont be as smooth and edited like the above one. I used FFD and protrude ruby's for this, hope this helps anyone wanting to make tires in the future.
                I attached the .skp too.
                [flash=600,350:3e515zqx]http://www.youtube.com/watch/v/v-rVsF5_k0E[/flash:3e515zqx]
                tyre.skp
                http://www.solos-art.com
                • soloS Offline
                  solo
                  I gave it another go, anyone need a Perelli tire?
                  http://img440.imageshack.us/img440/8188/perellirg6.jpg
                  perelli.skp
                    Click Draw
                    Thanks Solo,
                    Really good tut. I didn't know you could use protrude on any other shape besides square/rectangle. I learn here every day. Cool render.
                    Cheers,
                    Jeff
